Tobas Regular Visitor
Posted: Sun May 11, 2008 11:55 am Post subject: |
Un-installed, zapped a TomTomHome2 folder where you said it would be and now running 1.92, cheers! |
Elastic Occasional Visitor
Posted: Mon May 12, 2008 10:58 am Post subject: |
Tobas wrote: | Un-installed, zapped a TomTomHome2 folder where you said it would be and now running 1.92, cheers! |
I'm glad it worked....
Musketter Regular Visitor
Posted: Sat May 17, 2008 10:15 pm Post subject: Thanks Elastic |
It worked for me as well !
Keith |
Gazzadrum Occasional Visitor
Posted: Mon May 26, 2008 11:17 am Post subject: Re: Thanks Elastic |
And it worked for me, although I had to find and delete more than one old TomTom folder - thanks to all for the help in pointing me in the right direction!  |
zYx Occasional Visitor
Posted: Fri May 30, 2008 11:43 pm Post subject: |
i have a fresh vista ultimate and when i open tthome 2.3.1.92 it crashes as soon as i open tthome and chose device..
any ideas?
tthome 2.3... worked before on my vista. also that version doesn't work on my girlfiends laptop.. |
Posted: Sat May 31, 2008 9:33 am Post subject: |
I also use Vista Ultimate and have no problems running 2,3,1,92 with my TomTom hardware without problems, I would try removing the application from your PC download a fresh copy from This Page, it should then work - Mike |
BigBluesy Occasional Visitor
Posted: Sat Oct 11, 2008 10:23 am Post subject: |
Large_uk wrote: | I can't get it to run on XP Home. It downloads ok, but when I try to start it up, I get the error "HOMEruntime.exe failed with error 0: Process failed to start up correctly".
It advises me to re-download from the TomTom website, but exactly the same thing happens.
I'm now stuck without a recent version of TomTom Home... any ideas anyone? |
Uninstall current version - download update then when installing ensure you install to "C:\TomTom HOME 2" NOT C:\Program files\Tom Tom HOME 2
This should then work(hopefully) |
IanS100 Frequent Visitor
Posted: Sat Oct 11, 2008 11:17 am Post subject: |
BigBluesy wrote: | Large_uk wrote: | I can't get it to run on XP Home. It downloads ok, but when I try to start it up, I get the error "HOMEruntime.exe failed with error 0: Process failed to start up correctly".
I hope Largre_uk hasn't been waitng around since May for an answer  |
