Pocket GPS World :: View topic - Please help me
Please help me
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
ZInxyx
PostPosted: Fri May 09, 2008 7:46 pm    Post subject: Please help me Reply with quote
Hi guys,
I have had my O2 XDA stellar for about 6 months.This evening I tried to set up for first time use third party (black berry connect )software that came with the device.After following the prompts it asked me to tap ok to reboot the device.Now it's only showing the Windows Mobile screen and everything is frozen including hardware keys.
I tried to hook it up to me pc and the message I get is device locked .Can anybody help me out please?
Thanks.
PostPosted: Fri May 09, 2008 7:48 pm    Post subject: Reply with quote
Have you tried a reset?
ZInxyx
PostPosted: Fri May 09, 2008 7:53 pm    Post subject: Reply with quote
I've tried several times but still no joy. Got my friend to phone me call came through but after I hung up screen still shows incoming call.
PostPosted: Fri May 09, 2008 8:01 pm    Post subject: Reply with quote
If you're willing to try, it may be time for a hard reset? This will return it to out of the box state. You will lose any data on the device.
This must not be performed whilst the device is connected and or charging.
  1. Press and hold both soft keys
  2. Using a stylus, press and hold the soft reset button at the bottom of the phone
  3. Keep all three buttons pressed until the keypad lights turn off and then flash
  4. Release the soft reset button while still pressing the soft keys
  5. Let go of the two soft keys once the message "This operation will delete all your personal data, to manufacturer default" appears on screen
  6. Finally press the green call button to perform the hard reset or press other key to cancel
ZInxyx
PostPosted: Fri May 09, 2008 8:06 pm    Post subject: Reply with quote
Thanks Darren, I dread that is that the only option?
PostPosted: Fri May 09, 2008 8:43 pm    Post subject: Reply with quote
One possible other thing to try is removal of the battery for a while then put it back in and power up the device, if this doesn't cure it there is little option than trying the hard reset.
If you do end up hard resetting the device the first thing you should try is installing the software that caused it to go wrong, if it fails again then you loose nothing. There are some pictures on Here that show battery removal - Mike
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.063 (19 Jun 24)
