Pocket GPS World :: View topic - ITNconv Via Michelin
jkm
PostPosted: Fri May 02, 2008 8:05 pm    Post subject: ITNconv Via Michelin Reply with quote
Travelling down to Spain from UK,from home to Portsmouth no problem but i want to use Via Michelin from Bilbao to Granada it gives me the roads i want to travel on A1,M50,R4 and A4.
I used ITNconv to convert to itn file but the file only contains Bibao & Granada, when i try to use it on 700 it shows Bilao & Granada but seems to want to plan the route from my home address.
Am i trying to do something that is not possible to do ?
jkm
PostPosted: Mon May 05, 2008 9:05 pm    Post subject: Reply with quote
The itn file only contains POINTS to travel through not the entire route.
If the generated itn file only contains the two end points then the TomTom would make its own routing decision which way to go between them.
You would need to add several way points in ViaMitchelin to force a closer route to what you want.
As for starting from your home address (or actually your present location) that's how it always works. you could use the on-screen emulator in Home if you want - that has a facility to adjust your "present location" to where ever you like.
22.123 (18 Dec 24)
