Pocket GPS World :: View topic - Help installing Haicom Cf302E and TT2
MrMrMr
PostPosted: Thu May 13, 2004 2:29 pm    Post subject: Help installing Haicom Cf302E and TT2 Reply with quote
I have a Haicom CF302E and a ipaq 2210 and TomTom Nav 2. Can you please help me install the CF card
Also what is the best way to install, ie in what order, ie app, maps GPS driver etc?
Also what version of GPS driver from TT should I use?
What setting shall I set on the TT for my CF card? ie NMEA? or whatever?
thanks
PostPosted: Thu May 13, 2004 3:28 pm    Post subject: Reply with quote
- install the CF card and any drivers it may require
- TTN2.24 and voice file
- TT GPS 2.07
- any maps you need
For setup, select NMEA 4800 on port COM4 (or whatever your cf card is exposing). Try avoiding to use special CF card entries, stay with the basic selection. Try other speeds if 4800 doesn't work
MrMrMr
PostPosted: Thu May 13, 2004 7:50 pm    Post subject: Reply with quote
What do you out the GPS card type as, there is a TomTom selection, a Haicom and a generic and many others?
cheers
PostPosted: Fri May 14, 2004 3:30 am    Post subject: Reply with quote
As I said, try not to use any specific settings. Somehwere in the list must be the COM port that your card is exposing, use that.
DavidW
PostPosted: Fri May 14, 2004 5:55 pm    Post subject: Reply with quote
Use NMEA 0183v2 4800 for an Evermore based GPS - Haicom GPS is actually a setting for SiRF based GPSes.
The port is probably CF_CARD_GENERIC on a Haicom CF GPS.
DavidW
PostPosted: Fri May 14, 2004 5:58 pm    Post subject: Reply with quote
Why is it only after you press Submit that you realise you left something out? Posting with flu isn't always the best idea...
All Haicom GPSes where the model code ends in E are Evermore based - so your CF card is Evermore based (hence the recommendation to use NMEA 0183v2 4800).
22.064 (26 Jun 24)
