Pocket GPS World :: View topic - Help with Garmin Foretrex 201
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
spirit_of_will
PostPosted: Wed Apr 30, 2008 3:12 pm    Post subject: Help with Garmin Foretrex 201 Reply with quote
Hi All - just found this site after googling for help with my Foretrex 201.
I use the 201 mainly for windsurfing (GPS Speedsailing), running and mountain biking.
One of the main things that I wanted to do was to be able to download the tracks and add them to the GPS Speedsailing windsurfing speed rankings.
My main (first of many no doubt) question is related to the cable that comes in the box to hook the 201 up to a PC. The 9-pin connector doesn't match up with any of the ports on either my desktop or laptop.
Is there a specific adapter that I should use? I can't seem to find any USB cables that would fit the 201's tiny socket... Not terribly keen on getting it wrong and frying either the GPS or my PC!!!
Grateful for any help...
Thanks!
Will
Prodnose
PostPosted: Wed Apr 30, 2008 6:35 pm    Post subject: Reply with quote
Don't have a Foretrex 201 but looking at the manual indicates that it only a RS232 serial connection. Your mention of a the 9 pin plug confirms this. RS232 serial connections was routinely supplied with older PCs but now are rare. I have both a desktop and portable and neither has one. The solution is to use a USB to serial converter. In the case of the portable, a PCMCIA card with serial output may be use instead.
I own both types.
The USB/serial is a Bandridge - www.bandridge.nl - The model I use seems to have been discontinued but the BCP5002 seem to fit the bill.
The PCMCIA card is supplied by Quatech - www.quatech.com - I use the SSP-100 which is still listed on their website.
These a not the only suppliers and I have not researched the best, just made a choice and they work. It's worth searching this site for other recommendations.
Finally, if you look for second hand devices, make sure that you get the appropriate drivers.
Harry
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
23.053 (21 May 25)
