nickpa Occasional Visitor
Posted: Tue Apr 29, 2008 11:04 am Post subject: Loading GPS Database onto CoPilot 7 |
Sorry but I am a real numpty when it come to trying to load the database onto my CoPilot 7. I have the following problems:
a. Its says download the CSV file but there are 6 different camera files and 6 different bmp file. what do I need to do?
b. I deleted all file in the relevant folder that started with ao as directed and replaced them with the 12 files as above. The update seemed to work but there are no cameras on the map when I run through a previous journey. Any Ideas?
c. The custom POI is grayed out and I can not tick the box in the POI section to show on map. Any ideas?
d. The safety camera button in the setting menu is grayed out and so I can not select it. Any Ideas?
Many thanks in advance for any help of assistance you may be able to offer. I can not try the system running as I am overseas at the minute, maybe it will be ok but thought that I owuls ask anyway. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15157 Location: Bradford, West Yorkshire
Posted: Tue Apr 29, 2008 2:54 pm Post subject: |
when you restarted CP7 did it come up with a green bar in the middle of the screen saying it was processing updates or something like that?
MaFt |
Posted: Tue Apr 29, 2008 6:02 pm Post subject: |
Thanks for the v prompt response. Yes it did It said it was intergrating the updates.
Nick |
Posted: Tue Apr 29, 2008 6:05 pm Post subject: |
i've not got CP7 installed at the moment so this is from memory, i believe the speed cameras come under custom poi's rather than actual speed cameras. they still work as expected though.
MaFt |
Posted: Wed Apr 30, 2008 12:58 pm Post subject: |
Thanks again. I think that you are right the only problem being that when you enter the settings menu and navigate to the POI section the whole of the line where the custom POIs is on the menu is grayed so you can not tick the box. Any ideas? |
Posted: Wed Apr 30, 2008 1:10 pm Post subject: |
are they all greyed out or just the custom pois one?
MaFt |
Posted: Wed Apr 30, 2008 3:43 pm Post subject: |
Just the POI! |
rowejmc Occasional Visitor
Posted: Wed Apr 30, 2008 8:46 pm Post subject: |
I have experienced exactly the same thing. In my case I deleted the AO files and replaced them with only the CSV files. On restarting Copilot 7 speed cameras were visible.
The custom POI is also greyed out so I can't turn it on or off. I have enabled safety cameras though.
On my way to work I pass over the A11 where two mobile cameras are known to sited. The cameras are visible but I had no warning. As I only loaded the database last night I haven't had chance to test it properly so am hoping the warning didn't kick-in due to the direction I was travelling i.e. not on the A11 but over it.
One other thing I've noticed is that although the safety camera icon is as per the original Copilot symbol, if you click on it it says it is a Custom POI (not a Safety Camera POI). |
Posted: Fri May 02, 2008 12:42 pm Post subject: HELP |
I still have had no luck with transferring the database. I have reinstalled the ALK one and it works fine. I tried had another go at deleting the AO files and replacing with the GPS datbase file but no luck again and the safety camera button in the settings menu is still grayed out. We keep talking about .csv files hin the forum but the files I transfer are excel spreadsheet files! Any help appreciated. |
Posted: Fri May 02, 2008 1:01 pm Post subject: |
csv files will, by default, open with excel hence the simiar icon to excel. if you right-click the file and look at its proerties you will see that it is actually a csv file
MaFt |
Posted: Fri May 02, 2008 1:10 pm Post subject: |
Thanks for that info do you have any other advice as to how I might get the system working using the gps database, given the problems I am having. VMT |
nivek22 Lifetime Member
![](modules/Forums/images/avatars/2061115582475c1c2d9b8a6.gif)
Joined: Mar 09, 2006 Posts: 194 Location: Barnsley, South Yorkshire.
Posted: Fri May 02, 2008 1:56 pm Post subject: |
nickpa wrote: | whole of the line where the custom POIs is on the menu is grayed so you can not tick the box. Any ideas? |
I believe that's normal.
Goto Menu, settings, Safety Alerts. Tick the box and select a distance to be warned at. |
np947 Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_001.gif)
Posted: Fri May 02, 2008 2:52 pm Post subject: HELP |
Thanks for the info, but with I try to load the GPS database the safety alerts button is also grayed out !! |
