Pocket GPS World :: View topic - Aerial for Nuvi 250w
pj123
PostPosted: Sun Apr 27, 2008 3:52 pm    Post subject: Aerial for Nuvi 250w Reply with quote
I am thinking of buying a 250w to replace my Garmin PDA based navigator. I am using an external aerial with my Holux236 receiver as the windows on my car interfere with reception. I expect to have the same problem with the receiver in the 250w and I have looked for an aerial for the 250w on Ebay and elsewhere but cannot find one. I would be grateful if someone could advise where I can find one to order at the same time as the 250w.
Brickie64
PostPosted: Sun Apr 27, 2008 4:41 pm    Post subject: Reply with quote
I would imagine that the Garmin takes an MCX connector for the antenna.
This is probably the same as your existing one.
Might be worth a visit to your local shop to have a look at the 250W and see if your existing one is suitable.
I'm pretty sure you can get adapters for the different kinds of connector at the MAPLIN store if you find it needs the "mini MCX" (MMCX) instead.
You might find that a more modern GPS with a higher sensitivity receiver will actually work fine without the antenna in any case.
Take your car to the shop and give it a try.
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible"
Garmin Nuvi 3598 + GO 720 (+USA Map Card) + NavFree for iPhone in case all else fails ;-)
PaulB2005
PostPosted: Sun Apr 27, 2008 6:04 pm    Post subject: Reply with quote
IF (and it's a strong if with modern receivers) you need an antenna this one is probably the one you need.
It's the same one that i used with my i3 and also works with my Nuvi 760 - not that i need it....
Scarecrow
PostPosted: Mon Apr 28, 2008 5:39 pm    Post subject: Reply with quote
I've got that one and it works fine with my 360, 760, and GP12XL.
The magnet is good and strong, and it sits on the outside of the car (if that's where you want to put it) with no fear of getting blown off.
PaulB2005
PostPosted: Mon Apr 28, 2008 7:08 pm    Post subject: Reply with quote
I stuck mine on top of the rear view mirror and routed the cable into the head linig and down into the dashboard. Then it came out of a hole i made in a speaker cover.... Some pics here from way back somewhere..
pj123
PostPosted: Mon Apr 28, 2008 7:38 pm    Post subject: Reply with quote
Thank you for the useful replies. My aerial has an mmcx connector so i take it that this would not fit the 250w? When I get a chance I will take the aerial into a shop to see if it fits.
gilesme
PostPosted: Tue Apr 29, 2008 4:12 pm    Post subject: Reply with quote
Does the 250w have a socket for an external aerial ?
I have the 250 - think it's internal only ?
PaulB2005
PostPosted: Tue Apr 29, 2008 4:21 pm    Post subject: Reply with quote
The Set Up and Go manual doesn't show one...
PostPosted: Tue Apr 29, 2008 5:59 pm    Post subject: Reply with quote
in our focus the garmin i3 really struggled to get a satellite fix but the nuvi200 has had no problems at all.
i'd say it's safe to assume you shouldn't have any trouble
gilesme
PostPosted: Wed Apr 30, 2008 8:50 am    Post subject: Reply with quote
I got an external one for my I3, for use when using hire cars with athermic / heated windscreens.
As MaFt advises, never been a problem with the 250.
windup
PostPosted: Wed Apr 30, 2008 9:46 am    Post subject: 250W Reply with quote
I have just got a 250W. I can confirm the device has no external connectors apart from USB/charge cable socket.. not even headphone which surprised me.
However, I use mine situated in the caddy by the gear lever , well down in the car and once it has a signal it never fails. I even got a full signal while playing with the device in the middle of my lounge. Try it first b4 buying an aerial.
PS. What I have found is you need to get a signal b4 you move about...i.e. if you jump in the car, move off and then switch on.. it struggles to locate ..but this is logical if u think about it.
PPS.. once on the move, I have tried many times to confuse it by deliberatley changing suggested route and it will recalculate a new route instantly. Overall very impressive so far.
