chajun Regular Visitor
Posted: Thu Apr 24, 2008 8:06 pm Post subject: Safety cameras Tom Tom One V3 |
I have managed to install the latest camera data base from this site. They are displayed but so are the Tom Tom installed ones. how can I "switch them off"???? If I do will this then get rid of the speed limit displays
Thanks for any help. |
twotonemark Regular Visitor
Posted: Thu Apr 24, 2008 8:42 pm Post subject: |
Go to 'Change Preferences' and look for 'TomTom Safety Cameras' select it and look for a 'Disable alerts' and select it, click 'Done'.
Should see and hear only PGPS cameras and alerts. _________________ iPhone 6 - TomTom WE- CamerAlert - Brodit Passive Adjustable mount.
Oldboy Pocket GPS Moderator
Posted: Thu Apr 24, 2008 8:43 pm Post subject: |
The TomTom cameras are enabled/disabled in the TomTom PLUS Services Menu. Page 3 of the Main Menu.
The Speed display is controlled from the Status bar preferences and is a separate function. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Brickie64 Lifetime Member
Joined: Dec 05, 2007 Posts: 158 Location: Lincoln (UK)
Posted: Thu Apr 24, 2008 8:45 pm Post subject: |
Hi, Try this to disable the TT speed cameras. This is how my 910 works but it should be similar for your device
Tap the main screen to bring up the menu.... find the (TomTom PLUS Services) button and select it........find the (TomTom Safety Cameras) button and select it.........find the (Disable Alerts) button and then...(Done)
That should do it hopefully.
Good Luck
Gav _________________ "A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible"
Garmin Nuvi 3598 + GO 720 (+USA Map Card) + NavFree for iPhone in case all else fails ;-) |
Posted: Thu Apr 24, 2008 8:46 pm Post subject: |
Sorry Guys, didn't realise you'd beaten me to it whilst I was typing .......
(note to self....... MUST TYPE FASTER....)
Posted: Thu Apr 24, 2008 8:50 pm Post subject: |
Thanks have done that ok but will the road speed warning not display and be heard. Just ran a demo route cameras displayed but no speed warning chimes or visual speed limit warning. |
Posted: Thu Apr 24, 2008 8:58 pm Post subject: |
chajun wrote: | Thanks have done that ok but will the road speed warning not display and be heard. Just ran a demo route cameras displayed but no speed warning chimes or visual speed limit warning. | The Speed display is controlled from the Status bar preferences and is a separate function.
The Over Speed Warning is set up in Safety preferences.
Both of these are in Change Preferences. _________________ Richard
Posted: Thu Apr 24, 2008 9:04 pm Post subject: |
Thanks. Although Im not sure if I made myself clear. Prior to instalilng the new camera database when driving along a road the unit would flash up visualy top left of screen say the 30mph speed sign roundel and chime likewise for all speed limits. Also it would flash the roundel and chime when approaching a speed camera. When I ran the demo it didn't. Is this a feature only to be found from the official TT database |
Posted: Thu Apr 24, 2008 9:38 pm Post subject: |
Have you got the Speed Zoned Camera Database installed?
Have you used the Warn When Near Function to set up the warnings? _________________ Richard
Posted: Thu Apr 24, 2008 9:56 pm Post subject: |
Following on from what Oldboy asks if you do have the speed zone set have you got the .ogg sound files?
If yes to the above do the following for each speed zone listed.
If no to the sound files see http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=53604 before you do below.
Touch your screen, Change Preferences and locate Warn when near a POI
Select th first spped zone from the list
On the following screen select 'No'.
OK the distance.
Select YES.
Select 'Done'.
You'll return to
REPEAT FOR EACH SPEED LIMIT. _________________ iPhone 6 - TomTom WE- CamerAlert - Brodit Passive Adjustable mount.
Posted: Thu Apr 24, 2008 10:35 pm Post subject: |
A work of art thanks I shall plod on. |
Posted: Thu Apr 24, 2008 11:16 pm Post subject: |
Success thanks all |
Andy_P Pocket GPS Moderator
Posted: Fri Apr 25, 2008 12:40 am Post subject: |
I know you've said your happy now... but I've never let that stop me!
You said:
chajun wrote: | Prior to instalilng the new camera database when driving along a road the unit would flash up visualy top left of screen say the 30mph speed sign roundel and chime likewise for all speed limits. Also it would flash the roundel and chime when approaching a speed camera.
I'm afraid you must have been mistaken there. The round speed limit sign will ONLY flash in the top left corner on the approach to a speed camera (fixed or mobile) - its a POI alert.
It cannot be made to appear on just a speed limit change.
The only indication of speed limit may be in the speed display at the bottom of the screen (e.g. "65/70" meaning you are doing 65mph in a 70mph zone) and that only works on a percentage of roads, where the info has been coded into the map data. |
Posted: Fri Apr 25, 2008 9:02 am Post subject: |
Not mistaken the roundel flahes the speed limit even when there is no speed camera nearby. |
Darren Frequent Visitor
Posted: Fri Apr 25, 2008 11:59 am Post subject: |
chajun wrote: | Not mistaken the roundel flahes the speed limit even when there is no speed camera nearby. |
And which database do you have, single file? _________________ Darren Griffin |
