kichu1979 Regular Visitor
Posted: Thu Apr 24, 2008 3:22 pm Post subject: 2.3 TT HOME available to download |
Just spotted it. Check your "update" link inside the software. |
dgparryuk Occasional Visitor
Posted: Thu Apr 24, 2008 3:38 pm Post subject: |
installing on my work laptop... see how bad it is before i try it at home :D |
Posted: Thu Apr 24, 2008 3:42 pm Post subject: |
seems fine with 920 on xp home (dowloaded gpsfix, mapshare etc.)
no major changes visible from outside, I guess the new release has much to do with 930 and navcore 8 |
Posted: Thu Apr 24, 2008 3:43 pm Post subject: |
They've worked hard on this one...
already i spot something new, when it asks if you want to use internal or memory card there is now a image of a tomtom & an image of a tomtom with a memory card...
and there is a link to "personalize your tomtom"
but now it won't connect to the server :-P to update...
oh well...
tis working now...
mines also offering me two new computer voices...
Kate & Simon
and off again.... |
lancedavies Pocket GPS Verifier
Joined: Mar 30, 2008 Posts: 8 Location: 31880 LA SALVETAT SW FRANCE
Posted: Thu Apr 24, 2008 3:49 pm Post subject: |
My HOME v2.3 just installed and it downloaded Marshare & GPS fix but there is an update of KATE's voice which doesn't connect to server |
vicky Frequent Visitor
Joined: 12/08/2003 19:53:08 Posts: 264 Location: Secret Base in the Nevada Desert
Also cures the 930 no TTS Voices problem, as soon as 930 connected it offered download of the missing UK voices
I took off the temporary 920 voices patch I had on my 930 and reset it to a full unused backup connected to Home 2.3 and it downloaded the correct TTS voices for the 930, so that is that problem solved.
Still cannot use the navigate to spoken destination option as still greyed out on the 930
Can any of the mods who have been road testing the pre release 930s confirm if the navigate to spoken destination option is available on the versions they were supplied? |
Andy_P Pocket GPS Moderator
Posted: Thu Apr 24, 2008 4:25 pm Post subject: |
lancedavies wrote: | there is an update of KATE's voice which doesn't connect to server |
Neither does Simon's..."Error when contacting server: Not found"
Well done TomTom, another triumph! |
Posted: Thu Apr 24, 2008 4:46 pm Post subject: |
There is also a new version of the MapShare Corrections Counter Add-on. Now v1.2, was v1.1.
You have to get it manually, from the Tools Menu and, guess what.......?
It doesn't cure the 99999 corrections bug! If it doesn't count right, what else DOES it do? |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Thu Apr 24, 2008 5:15 pm Post subject: |
Andy_P2002 wrote: | It doesn't cure the 99999 corrections bug! If it doesn't count right, what else DOES it do? |
It makes sure posters such as yourself are kept busy detailing their screwups!
After all, if TomTom EVER did get it right, think of what posts here would look like:
"Hello, how are you?"
"Fine. How are you?" |
Posted: Thu Apr 24, 2008 5:29 pm Post subject: |
Vicky, the ASR works fine for nav to spoken adress and dialogue mode, although no ASR likes my accent, so I try it then avoid using it as tapping the screen is faster from my experience (it doesn't like Northerners), there must be other files which are messed up on the device, although I might be running a different software version to your unit - Mike |
xda Lifetime Member
Posted: Thu Apr 24, 2008 6:15 pm Post subject: |
You need to edit the indicator.xml file again and add the extra 9 to the two strings.
Just done mine and Home is showing 101,256 MapShare updates. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Thu Apr 24, 2008 6:26 pm Post subject: |
xda wrote: |
You need to edit the indicator.xml file again and add the extra 9 to the two strings. |
Yeah, but we shouldn't have to, should we!
When I saw they had done a new version, I assumed they must have seen our discussion (or had it pointed out to them by loads of people - I did)
My point was, its ONLY function is to count the corrections, what else was there to change, yet still leave it wrong! |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Thu Apr 24, 2008 6:37 pm Post subject: |
Looks like I may have to apply for that experienced mozilla developer job that they have, after all. If they can't get simple stuff like that fixed they obviously need a bit of help. |
forky Lifetime Member
Posted: Thu Apr 24, 2008 8:24 pm Post subject: |
xda wrote: | Andy_P2002 wrote: | It doesn't cure the 99999 corrections bug! If it doesn't count right, what else DOES it do? |
Just done mine and Home is showing 101,256 MapShare updates. |
Could you possibly point me in the right direction as to how to edit this xml file please
regards _________________ Garmin Nuvi 2699lmt
Samsung Galaxy S9 (o2) contract |
Oldboy Pocket GPS Moderator
Posted: Thu Apr 24, 2008 8:51 pm Post subject: |
forky wrote: | Could you possibly point me in the right direction as to how to edit this xml file please | Use Wordpad.
As a reminder the location is shown in This Post. _________________ Richard
TT Via 135 App 12.075: Europe Map v1140 |
