Pocket GPS World :: View topic - Safety cameras Tom Tom One V3
chajun
PostPosted: Thu Apr 24, 2008 8:06 pm    Post subject: Safety cameras Tom Tom One V3 Reply with quote
I have managed to install the latest camera data base from this site. They are displayed but so are the Tom Tom installed ones. how can I "switch them off"???? If I do will this then get rid of the speed limit displays
Thanks for any help.
twotonemark
PostPosted: Thu Apr 24, 2008 8:42 pm    Post subject: Reply with quote
Go to 'Change Preferences' and look for 'TomTom Safety Cameras' select it and look for a 'Disable alerts' and select it, click 'Done'.
Should see and hear only PGPS cameras and alerts.
iPhone 6 - TomTom WE- CamerAlert - Brodit Passive Adjustable mount.
PostPosted: Thu Apr 24, 2008 8:43 pm    Post subject: Reply with quote
The TomTom cameras are enabled/disabled in the TomTom PLUS Services Menu. Page 3 of the Main Menu.
The Speed display is controlled from the Status bar preferences and is a separate function.
Brickie64
PostPosted: Thu Apr 24, 2008 8:45 pm    Post subject: Reply with quote
Hi, Try this to disable the TT speed cameras. This is how my 910 works but it should be similar for your device
Tap the main screen to bring up the menu.... find the (TomTom PLUS Services) button and select it........find the (TomTom Safety Cameras) button and select it.........find the (Disable Alerts) button and then...(Done)
That should do it hopefully.
Good Luck Very Happy
Gav
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible"
Garmin Nuvi 3598 + GO 720 (+USA Map Card) + NavFree for iPhone in case all else fails ;-)
Brickie64
PostPosted: Thu Apr 24, 2008 8:46 pm    Post subject: Reply with quote
Sorry Guys, didn't realise you'd beaten me to it whilst I was typing .......
(note to self....... MUST TYPE FASTER....) Very Happy
Gav
chajun
PostPosted: Thu Apr 24, 2008 8:50 pm    Post subject: Reply with quote
Thanks have done that ok but will the road speed warning not display and be heard. Just ran a demo route cameras displayed but no speed warning chimes or visual speed limit warning.
PostPosted: Thu Apr 24, 2008 8:58 pm    Post subject: Reply with quote
The Over Speed Warning is set up in Safety preferences.
Both of these are in Change Preferences.
chajun
PostPosted: Thu Apr 24, 2008 9:04 pm    Post subject: Reply with quote
Thanks. Although Im not sure if I made myself clear. Prior to instalilng the new camera database when driving along a road the unit would flash up visualy top left of screen say the 30mph speed sign roundel and chime likewise for all speed limits. Also it would flash the roundel and chime when approaching a speed camera. When I ran the demo it didn't. Is this a feature only to be found from the official TT database
PostPosted: Thu Apr 24, 2008 9:38 pm    Post subject: Reply with quote
Have you got the Speed Zoned Camera Database installed?
Have you used the Warn When Near Function to set up the warnings?
twotonemark
PostPosted: Thu Apr 24, 2008 9:56 pm    Post subject: Reply with quote
Following on from what Oldboy asks if you do have the speed zone set have you got the .ogg sound files?
If yes to the above do the following for each speed zone listed.
If no to the sound files see http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=53604 before you do below.
Touch your screen, Change Preferences and locate Warn when near a POI
Select th first spped zone from the list
On the following screen select 'No'.
OK the distance.
Select YES.
Select 'Done'.
You'll return to
REPEAT FOR EACH SPEED LIMIT.
chajun
PostPosted: Thu Apr 24, 2008 10:35 pm    Post subject: Reply with quote
A work of art thanks I shall plod on.
chajun
PostPosted: Thu Apr 24, 2008 11:16 pm    Post subject: Reply with quote
Success thanks all
PostPosted: Fri Apr 25, 2008 12:40 am    Post subject: Reply with quote
I know you've said your happy now... but I've never let that stop me! Rolling Eyes
You said:
I'm afraid you must have been mistaken there. The round speed limit sign will ONLY flash in the top left corner on the approach to a speed camera (fixed or mobile) - its a POI alert.
It cannot be made to appear on just a speed limit change.
The only indication of speed limit may be in the speed display at the bottom of the screen (e.g. "65/70" meaning you are doing 65mph in a 70mph zone) and that only works on a percentage of roads, where the info has been coded into the map data.
chajun
PostPosted: Fri Apr 25, 2008 9:02 am    Post subject: Reply with quote
Not mistaken the roundel flahes the speed limit even when there is no speed camera nearby.
PostPosted: Fri Apr 25, 2008 11:59 am    Post subject: Reply with quote
And which database do you have, single file?
22.064 (26 Jun 24)
