Joined: Jun 19, 2006 Posts: 212 Location: Sahrf Lunnon ;)
Posted: Wed Apr 23, 2008 7:52 pm Post subject: Camera submission system doesn't seem to want to work?
Using: Firefox 2.0.0.14 with NoScript 1.6; and before you ask I have got scripts enabled. The system will not allow me to use the map to add coordinates to amend a camera. Tried three times, no joy.
So, in case you can do it from there, the previous submission I made on Kentish Way, centre island, forget. It's already on the database, dammit.
You have, however, got them the wrong way around
In addition, there's a sting in the tale on these two cameras... read on...
As you can see, this is the southbound view. Note the northernmost camera housing is in the central reservation, not the other way around as the map shows Also note the lack of road markings... (first dead give away)
Northern view from the southernmost camera housing. Again, no road markings. Give away number two
Northernmost camera housing. A bog-standard Monitron, you might think...?
WOT?! It's EMPTY!
And here's the confirming view, clearly showing the rear of the camera housing and the locking plate!
In other words:
These cameras are DUDS! _________________ Roger, G1LIW
Google Pixel 3a XL Android Smartphone | SatNav Sygic for Android | Waze for Android | CamerAlert for Android | Blog http://rogersblant.blogspot.com/
Posted: Wed Apr 23, 2008 11:28 pm Post subject:
Andy -
Yes.
Move Monitron:51560@30 from west side of road to the central reservation, and rotate to approx 160-165 degrees to a roughly southern facing. Box is confirmed as completely devoid of any camera unit.
Move Monitron:51559@30 from the eastern side of the road to the other (western) side of the road, and rotate to approx 005 degrees to a roughly northern facing. Box is confirmed as completely devoid of any camera unit.
NOTE AGAIN: nether carriageway has any speed camera road markings, there are no speed camera signs posted, and BOTH boxes are missing any form of camera installation - as evidenced by the photos
While you're in the database, have a look at the submissions stack, and remove and delete a rather inaccurate submission of mine, dated 19/04/2008 22:46 hrs, as follows:
Erroneous submission wrote:
Addition of: Reversible Monitron (ID#0), Heading: 0, Lat:51.4026326, Lon:0.01786351 (United Kingdom), Speed:30, new-type digital gatso, Kentish Way, Bromley, central reservation about 30 or so yards south of the walking bridge (about half-way between the junctions of Stockwell Close and Elmfield Road), currently facing south (reversible). I\'ve not seen any warning signs at present, so this should be a new one, despite the two near-side camera notes on the database - there weren\'t any nearside cameras that I could see (about 10:30pm on Saturday 19th April 2008).
I got the submission wrong, darn it damn things were already there! _________________ Roger, G1LIW
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Thu Apr 24, 2008 8:14 am Post subject:
There's a speed camera that I pass regularly, which has matrix signs a good hundred yards or so before it. If you're travelling at just above the speed limit, the matrix sign lights up with a 30 speed limit sign and if you're travelling slightly faster than that, the matrix sign adds an image of a speed camera (note, I've never triggered the matrix sign myself, but I've seen it triggered by others).
As a precaution, there are also the usual speed camera signs.
Thus, if you're speeding and you're too dumb to take action when the matrix signs lights up for you, then you deserve to get your photo taken by this camera. _________________ Andy
Posted: Thu Apr 24, 2008 11:01 am Post subject:
G1LIW wrote:
Andy -
Yes.
OK, will do.
I'll stick with my heading figures if that's OK.
Just for info, the present guidance is to locate the camera position in the middle of the carriageway ir is working on, rather than trying to accurately place it on the central reservation or verge. This is to assist slight discrepancies between the positional accuracy on all the various systems.
Similarly, if a camera on a central reservation is reversible, on the TomTom version of the database at least, it is marked as TWO camera positions, one on each carriageway.
Posted: Thu Apr 24, 2008 11:17 am Post subject:
Monitrons 51559 and 51560 now changed on submissions map.
I looked at your submission for Lat:51.4026326, Lon:0.01786351 that you wanted removed and although the precise point seems a little "off" from your description (see the crosshairs in the picture below), it seems to have either rejected/ignored already or not put on the system yet.
I have no way to access the whole database (only the team can do that), but if it has been added to the master list, I should be able to see your submission on my version of the map, and its not there. I'll send a note to MaFt, the database supremo, just to confirm he should ignore it.
Posted: Thu Apr 24, 2008 7:35 pm Post subject:
OK, thanks on all of that
Just to make sure, you have the one at the bottom of that map looking north, and the one to the top of the map looking south, correct? _________________ Roger, G1LIW
Posted: Fri Apr 25, 2008 12:13 am Post subject:
Yeah.
As per the labels:
#51559 at the bottom catches cars going north on a heading of ~350 and
#51560 at the top catches cars going south on a heading of ~170
Posted: Fri Apr 25, 2008 6:53 am Post subject:
Andy -
Cool - mucho thanks (Even if the boxes ARE empty, ) _________________ Roger, G1LIW
