Pocket GPS World :: View topic - Camera submission system doesn't seem to want to work?
G1LIW
PostPosted: Wed Apr 23, 2008 7:52 pm    Post subject: Camera submission system doesn't seem to want to work? Reply with quote
Using: Firefox 2.0.0.14 with NoScript 1.6; and before you ask I have got scripts enabled. The system will not allow me to use the map to add coordinates to amend a camera. Tried three times, no joy.
So, in case you can do it from there, the previous submission I made on Kentish Way, centre island, forget. It's already on the database, dammit.
You have, however, got them the wrong way around Very Happy
In addition, there's a sting in the tale on these two cameras... read on... Twisted Evil
As you can see, this is the southbound view. Note the northernmost camera housing is in the central reservation, not the other way around as the map shows Wink Also note the lack of road markings... (first dead give away)
Northern view from the southernmost camera housing. Again, no road markings. Give away number two Wink
Northernmost camera housing. A bog-standard Monitron, you might think...?
WOT?! It's EMPTY! Shocked
And here's the confirming view, clearly showing the rear of the camera housing and the locking plate!
In other words:
These cameras are DUDS! Very Happy
Roger, G1LIW
Google Pixel 3a XL Android Smartphone | SatNav Sygic for Android | Waze for Android | CamerAlert for Android | Blog http://rogersblant.blogspot.com/
PostPosted: Wed Apr 23, 2008 9:03 pm    Post subject: Reply with quote
Assuming they may actually get "innards" soon, am I right in thinking this is what you want to do?
If so, I'll submit the change for you if you would like me to.
G1LIW
PostPosted: Wed Apr 23, 2008 11:28 pm    Post subject: Reply with quote
Andy -
Yes.
Move Monitron:51560@30 from west side of road to the central reservation, and rotate to approx 160-165 degrees to a roughly southern facing. Box is confirmed as completely devoid of any camera unit.
Move Monitron:51559@30 from the eastern side of the road to the other (western) side of the road, and rotate to approx 005 degrees to a roughly northern facing. Box is confirmed as completely devoid of any camera unit.
NOTE AGAIN: nether carriageway has any speed camera road markings, there are no speed camera signs posted, and BOTH boxes are missing any form of camera installation - as evidenced by the photos Very Happy
Thanks Very Happy
While you're in the database, have a look at the submissions stack, and remove and delete a rather inaccurate submission of mine, dated 19/04/2008 22:46 hrs, as follows:
Erroneous submission wrote:
Addition of: Reversible Monitron (ID#0), Heading: 0, Lat:51.4026326, Lon:0.01786351 (United Kingdom), Speed:30, new-type digital gatso, Kentish Way, Bromley, central reservation about 30 or so yards south of the walking bridge (about half-way between the junctions of Stockwell Close and Elmfield Road), currently facing south (reversible). I\'ve not seen any warning signs at present, so this should be a new one, despite the two near-side camera notes on the database - there weren\'t any nearside cameras that I could see (about 10:30pm on Saturday 19th April 2008).
I got the submission wrong, darn it Sad damn things were already there!
Roger, G1LIW
GPS_fan
PostPosted: Thu Apr 24, 2008 8:14 am    Post subject: Reply with quote
There's a speed camera that I pass regularly, which has matrix signs a good hundred yards or so before it. If you're travelling at just above the speed limit, the matrix sign lights up with a 30 speed limit sign and if you're travelling slightly faster than that, the matrix sign adds an image of a speed camera (note, I've never triggered the matrix sign myself, but I've seen it triggered by others).
As a precaution, there are also the usual speed camera signs.
Thus, if you're speeding and you're too dumb to take action when the matrix signs lights up for you, then you deserve to get your photo taken by this camera.
Andy
PostPosted: Thu Apr 24, 2008 11:01 am    Post subject: Reply with quote
G1LIW wrote:
Andy -
Yes.
Thanks Very Happy
OK, will do.
I'll stick with my heading figures if that's OK.
Just for info, the present guidance is to locate the camera position in the middle of the carriageway ir is working on, rather than trying to accurately place it on the central reservation or verge. This is to assist slight discrepancies between the positional accuracy on all the various systems.
Similarly, if a camera on a central reservation is reversible, on the TomTom version of the database at least, it is marked as TWO camera positions, one on each carriageway.
[quote="Erroneous submission"]Addition of: Reversible Monitron (ID#0), Heading: 0, Lat:51.4026326, Lon:0.01786351 (United Kingdom),
I'll do that too.
PostPosted: Thu Apr 24, 2008 11:17 am    Post subject: Reply with quote
Monitrons 51559 and 51560 now changed on submissions map.
I looked at your submission for Lat:51.4026326, Lon:0.01786351 that you wanted removed and although the precise point seems a little "off" from your description (see the crosshairs in the picture below), it seems to have either rejected/ignored already or not put on the system yet.
I have no way to access the whole database (only the team can do that), but if it has been added to the master list, I should be able to see your submission on my version of the map, and its not there. I'll send a note to MaFt, the database supremo, just to confirm he should ignore it.
G1LIW
PostPosted: Thu Apr 24, 2008 7:35 pm    Post subject: Reply with quote
OK, thanks on all of that Smile
Just to make sure, you have the one at the bottom of that map looking north, and the one to the top of the map looking south, correct?
Roger, G1LIW
PostPosted: Fri Apr 25, 2008 12:13 am    Post subject: Reply with quote
Yeah. Smile
As per the labels:
#51559 at the bottom catches cars going north on a heading of ~350 and
#51560 at the top catches cars going south on a heading of ~170
G1LIW
PostPosted: Fri Apr 25, 2008 6:53 am    Post subject: Reply with quote
Andy -
Cool - mucho thanks (Even if the boxes ARE empty, Laughing Out Loud) Laughing
Roger, G1LIW
22.063 (19 Jun 24)
