Pocket GPS World :: View topic - Go 720 - Increase Performance?
jonmat
PostPosted: Mon Apr 21, 2008 8:58 am    Post subject: Go 720 - Increase Performance? Reply with quote
Can anyone point me to any previous posts on how to improve the performance of my 720. When I say performance I am referring to the speed it updates when you are driving along, quite a few times I have found that I get to a junction with a couple of exits or a roundabout and it's not entirely clear which one to take as the 720 hasn't quite got there. I think it is also referred to as lagging. I used to get a similar problem on the Navigator 5 on my PDA but this was when I had too many POI's visible, if I removed a few it worked ok. I have only got about 10 POI's visible on the 720.
Any help would be much appreciated.
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Apr 21, 2008 10:20 am    Post subject: Reply with quote
Try disabling the POI files as they can and do slow the map refresh rate down on the PNA units if you add loads to it. I suggest you use the warn when near POI instead, as per the TT Nav 5 & 6 which should fix it - Mike
jonmat
PostPosted: Mon Apr 21, 2008 10:23 am    Post subject: Reply with quote
Thanks Mike, haven't got loads of POI's though. Does moving files to a memory card and freeing up space on the device help?
PostPosted: Mon Apr 21, 2008 10:29 am    Post subject: Reply with quote
POI files have to reside in the map folder which has to remain in one place, it can be either internal memory or SD card, you cannot split the map file or its contents to span two locations. I first noticed the lagging on my 720 after installing about 100 POI Categories, so this could be same issue you have - Mike
PostPosted: Tue Apr 22, 2008 12:34 pm    Post subject: Reply with quote
There's also update RATE.
If your screen updates about three times a second as you are driving along a straight section of road (get a passenger to count it like taking a pulse), then that is about right.
D4VE
PostPosted: Tue Apr 22, 2008 6:43 pm    Post subject: Reply with quote
My 520 updates at about 10 times per second when I am doing about 150MPH. Laughing Out Loud
iPhone4 IOS 4.3.3
TomTom Western Europe v865.3252
App 8.300 V1.6 (670441)
TomTom iPhone Car Kit
PC Operating System: Windows 7
22.063 (19 Jun 24)
