dmac Regular Visitor
Joined: 18/08/2003 22:18:21 Posts: 117 Location: United Kingdom
Posted: Mon May 10, 2004 9:01 pm Post subject: TTN3 routing funnies |
Journey from Brunton Lane Newcastle NE3 2 to Eastgate Hexham Ne46 directs you onto main Newcastle Carlisle road A69 dual carriageway which
is what I would expect.
But, then it directs you away from A69 and onto B6318 which in turn
joins A68 which in turn takes you back onto A69
All my setting on TTN3 are set at default values but this route
just seems mad..............
I bought TTN3 to save me time and NOT take me silly detours.
Seems not just missing roads but daft routing
Cheers |
R1chard Regular Visitor
Posted: Mon May 10, 2004 10:00 pm Post subject: Re: TTN3 routing funnies |
dmac wrote: | ..this route just seems mad.............. |
It certainly does! I just tried a few other routes e.g. Stannigton (near Morpeth) to Carlisle and it does the same thing. In particular it seems odd that it routes you through the small town of Heddon-on-the-Wall. I've just done some measurements on Autoroute and the B road route seems to add .9 miles to the route.
I've used this route regularly over the last 6 months or so and I know that TT2 was quite happy with the A69 (although it had a few miles missing further west around Haltwhistle).
Maybe an email to TomTom support would be in order.
Richard |
iancjc Frequent Visitor
![](modules/Forums/images/avatars/avatar_sp_034.jpg)
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Mon May 10, 2004 11:08 pm Post subject: |
I can't check this at the moment but You may want to look at the map as this section of the road maybe "un known" which tomtom will then avoid like the plague as (I guess) it will not know what standard of road or track it is and ignore it.
I have come up against something similar with a new bypass where the middle 300 yards is unkown and you get routed off through an industrial estate and back onto the bypass at the next roundabout where the road is correctly listed once more.....
I guess you just learn to ignore it where you know the way or signs point in an obvious direction - gps really comes into its own for the last few miles through towns - probably best to flag this up as a map error. _________________ -----------------------------------------------------------
TTN6.03 tomtom 7.xx (one) |
icsys Frequent Visitor
![](http://www.getoutguide.pwp.blueyonder.co.uk/screenshot/Animation3.gif)
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Tue May 11, 2004 12:00 am Post subject: |
Out of curiosity I tried this with Navman SmartSTv2 and it also routes away from the A69... but not in the same place!
It routes you off the A69, through Ovington then back up the B6309 and back onto the A69 at the next junction? |
Posted: Tue May 11, 2004 1:29 pm Post subject: |
iancjc wrote: | You may want to look at the map as this section of the road maybe "un known" which tomtom will then avoid like the plague ... |
No, it's not "unknown" and it definitely wasn't a problem with TT2.
Richard |
Mat_Wal Occasional Visitor
![](modules/Forums/images/avatars/avatar_ani_005.gif)
Posted: Tue May 11, 2004 2:00 pm Post subject: Strange journeys |
I think TT are having problems, I emailed them nearly a week ago as since upgrading to TTN3 I'm now sent down dirt tracks, deep fords (14in sadly I measured the water mark on my 4x4) and on bridleways.
Still waiting for the answer
Yes I do have a 4x4 but this does help when towing a caravan |
Posted: Tue May 11, 2004 5:29 pm Post subject: |
iancjc wrote: |
I have come up against something similar with a new bypass where the middle 300 yards is unkown and you get routed off through an industrial estate and back onto the bypass at the next roundabout where the road is correctly listed once more..... |
Out of interest reversed the route and no probs, I was directed along the
A69.
So, perhaps there is a break in road routing alignment when travelling
west but dual carriageway travelling east in OK.
That being the case would also suggest that all mapping data was renewed
rather than add/delete change.............interesting.....
Cheers |
Tim Buxton Pocket GPS Moderator
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Tue May 11, 2004 5:42 pm Post subject: |
icsys wrote: | Out of curiosity I tried this with Navman SmartSTv2 and it also routes away from the A69... but not in the same place!
But no problems with the reverse route! Can you do me a favour and try to route from Land's End to John O'Groats, then the reverse trip, please? I'd be interested if a TTN3 user could do this, too, please. _________________ Tim |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Tue May 11, 2004 11:15 pm Post subject: |
TT3 user - Land'S End (Cornwall) to John O'Groats (Highlands) 14 hrs 54 mins 835.9 miles........ John O'G to Land's End 14 hrs 55 mins 836.2 miles.
Steve |
Posted: Wed May 12, 2004 7:16 am Post subject: |
Steve,
Did you go to the very end of Land's End, i.e. the roundabout right at the end where the Land's End Hotel is? _________________ Tim |
Barry320SLK Occasional Visitor
Posted: Wed May 12, 2004 9:33 am Post subject: |
I've been a user of TT for over a year now. My route to work has changed since the launch of TT3 apparently. That I suppose I can live with, but there is something more aggravating.
I travel from Southport to Stockport and back, which logically would take you down the M60. However the M60 is a nightmare so avoiding it saves me time.
With TT2 I would ask to avoid the M60 once I was on the M6, I would be routed further down the M6 and down the M56 off at Jcn 6, good route. Now I issue the avoid M60 command and I get routed further down the M6 as normal. However once on the M56 TT3 wants to put be back on the M60! I have to reissue a command issued minutes earlier.
Is it a fairly simple job to uninstall TT3 and reinstall TT2 and the old maps? |
Posted: Wed May 12, 2004 10:54 am Post subject: |
Tim
I have routed from LE to JoG, what exactly do you need from this?
Distance = 822.8 miles |
tom9851 Frequent Visitor
Joined: Feb 14, 2004 Posts: 283 Location: Warrington, Cheshire.
Posted: Wed May 12, 2004 11:29 am Post subject: |
Barry320SLK,
Yes it's no big deal to re-install TTN2 (if I can do it anyone can!). I just deleted all the TomTom files from both the Ipaq and the SD card and installed TTN2. When you get to the end of the installation and the TTN2 CD asks you if you want to register it just ignore that bit - since you have activated it already on the same device then no problem. All the other stuff you may have on there like postcodes and cameras etc just leave it will all work fine - at least it did for me. I don't know if you can just reinstall TTN2 over TTN3 without deleting all first - try that it will certainly be quicker. I assumed you couldn't so I cleared it all out first, but I could be wrong about that.
Tom |
Posted: Wed May 12, 2004 2:06 pm Post subject: |
icsys wrote: | Tim
Because although I can do LE to JO'G, I can't do JO'G to LE! I wondered if it was a Navman thing or a TeleAtlas thing, that's all. _________________ Tim |
Posted: Wed May 12, 2004 10:49 pm Post subject: |
Tim Buxton wrote: | Steve,
Did you go to the very end of Land's End, i.e. the roundabout right at the end where the Land's End Hotel is? |
Tim,
With TT you can just input the town and do a carriage return and it calculates from the centre of the town. Give or take a couple of miles it was still one end of the country to the other
From the un-named roads at Long 005deg 42'54' Lat 050deg04'05' to Long 003deg01'34 lat 058deg38'38' which is the furthest points I can get, the distance is 838.2 miles and time 15.11 hours......... ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
