Pocket GPS World :: View topic - Has anyone used the LiPol battery pack yet?
Goto page Previous  1, 2, 3
IanHibbert
PostPosted: Tue Apr 08, 2008 6:12 pm    Post subject: Reply with quote
Does the rechargeable pack need to be removed to stop it draining under v1.16?
PostPosted: Tue Apr 08, 2008 6:14 pm    Post subject: Reply with quote
Not from my experience.
PostPosted: Tue Apr 08, 2008 8:22 pm    Post subject: Reply with quote
Having just tried measuring the current drawn from the active10 while switched off I get no noticable difference between the battery plugged in to the device or when disconnected, so it looks like the current draw issue might have been resolved.
I will try this test with other measurment equipment to make sure but the kit I used is good enough for a quick "look see" :
CFD 200 CF DMM card
ipaq-4700 PDA
Fluke i30 Clamp
There is a picture of this set up which I have used before for similar testing, the only difference this time was the new software and the rechargable battery:
Mike
IanHibbert
PostPosted: Tue Apr 08, 2008 11:15 pm    Post subject: Reply with quote
Thanks folks, looking good at last!
Paul_ffitch
PostPosted: Fri Apr 11, 2008 8:06 pm    Post subject: Reply with quote
Sorry to damp this hope down, but I have just measured the current consumption of my 1.16 Satmap when switched off. It show at the same 32 to 34mA that it did on V1.03 of the firmware. So I'm afraid it looks like we will have to keep on taking the batteries out...
lucevans
PostPosted: Fri Apr 11, 2008 9:46 pm    Post subject: Reply with quote
Was that using AAs? There has been some suggestion that the same inconvenient power-off drain doesn't occur for some reason when using the dedicated Lipol battery.
Has anyone confirmed or disproved Mike's data when using the LiPol battery?
PostPosted: Sat Apr 12, 2008 9:26 am    Post subject: Reply with quote
My multimeter is flat so I haven't measured it but I can confirm from my usage that there is no observable loss of charge when left unused for three days.
Paul_ffitch
PostPosted: Sat Apr 12, 2008 9:56 am    Post subject: Reply with quote
I measured the 32mA drain with rechargable NiMH AAs. Not sure why LiPOL would be different, but I can't confirm as I haven't got one.
PostPosted: Sat Apr 12, 2008 10:11 am    Post subject: Reply with quote
It connects differently which may have some bearing on the issue?
PostPosted: Sat Apr 12, 2008 11:32 am    Post subject: Reply with quote
I decided to try this again as I have more time available today, measuring low current with a clamp is never too easy, to increase the signal being measured I made ten turns of cable through the head of the clamp, this works out to 1mV = 1mA when used this way.
First of all with the active10 not connected the probe is set as close to zero as possible
When connected, with the active10 off there is around the 32-34mA as can been seen on the iPAQ display
This constant burden will eventually flatten the battery, but as it is rechargeable this is not as much of an issue as flattening Lithium disposable cells was.
When I tried this the other night with a single pass through the probe the signal was so low it was lost in the noise as the meter reading wanders around by +/-2mV - Mike
lucevans
PostPosted: Sat Apr 12, 2008 1:47 pm    Post subject: Reply with quote
Thanks for doing the test mike. Thumbs Up
Does anyone know whether this constant drain is an issue that could be fixed in firmware, or is it a limitation of the hardware?
Page 3 of 3
23.032 (12 Mar 25)
