Pocket GPS World :: View topic - TMC miniscan signal strength
ijhill
PostPosted: Wed Apr 09, 2008 11:34 am    Post subject: TMC miniscan signal strength Reply with quote
I have used a miniscan arial, although, brought from Rocketradio.net it covers the FM band and goes down to 25Mhz.
After connecting it the signal strength on the hidden screens drops from around 37 to 22 in Wolverhampton, however, the frequency never changes from 97 and receives traffic really well.
Is this normal, I can imagine that the increased cable length +5m increases signal loss but the external aerial improves signal quality. In any case I now receive traffic information on my drive and in a couple of seconds which is great, waiting to see how this works elsewhere.
PostPosted: Wed Apr 09, 2008 11:47 am    Post subject: Reply with quote
If it works better with the aerial connected than without simply ignore the hidden menu's and any signal strength meter on the device, they are meaningless at best, misleading at worst.
I have used a Mini-Scan and Sky-Scan aerials to great effect in the UK with various RDS-TMC receivers, far better than the cr*ppy bit of shoe lace they all seem to like supplying - Mike
PaulB2005
PostPosted: Wed Apr 09, 2008 11:56 am    Post subject: Reply with quote
Any chance of some part / stock numbers for places like Maplin etc for this sort of item?
Also how did you connect the shoe string to the antenna?
Some sort of idiots guide to doing this? I've read a few threads on this and because i've never done anything like this before it goes a bit over my head..... Embarassed
ijhill
PostPosted: Wed Apr 09, 2008 11:57 am    Post subject: Reply with quote
Thanks Mile, I did disconnect the aerial and although the signal increase I got a yellow flashing light so the signal quality has definitely improved. a rival now for tomtom traffic.
ijhill
PostPosted: Wed Apr 09, 2008 12:02 pm    Post subject: Reply with quote
This is the one I got as it covers more of the FM spectrum http://www.rocketradio.co.uk/discrete-miniature-car-scanner-antenna-96-p.asp
I also got the BNC connector http://www.rocketradio.co.uk/inline-bnc-socket-984-p.asp, soldered the garmin string to the centre pin (after removing the end), then I can connect and disconnect the garmin string from the aerial BNC connection.
PaulB2005
PostPosted: Wed Apr 09, 2008 12:11 pm    Post subject: Reply with quote
Ah, thanks.
Ok stupid question(s). The antenna on the end? Absolutely necessary of can a length of suitable cable be used - got plenty of 16/0.2 wire lying around.
BNC Connectors necessary or could you use this and this to make the join?
PostPosted: Wed Apr 09, 2008 12:37 pm    Post subject: Reply with quote
The Mini Scan only goes down to 100MHz but it works very well for RDS-TMC, better still it doesn't look like an aerial farm stuck on the roof see Mini-Scan for more details.
If you don't mind drawing attention to the vehicle consider the Sky-Scan, this goes down to 25MHz and is therefore more suitable for the FM band 87 - 108 MHz Sky-Scan
On either case you are better to connect the aerial to the RDS-TMC via a decent connector, the 50 ohm BNC connector isn't costly and will offer less attenuation than banana jacs see
BNC Socket
Mike
PaulB2005
PostPosted: Wed Apr 09, 2008 12:50 pm    Post subject: Reply with quote
So the "Round BNC Chassis Socket" HH18U just literally solders onto the end of the TMC antenna (after removing the end block and striping the insulation) at the centre pin (the gold spike top right of the picture?)
The antenna BNC connector just twists on and off the other end?
PostPosted: Wed Apr 09, 2008 12:56 pm    Post subject: Reply with quote
What you describe is exactly what I have done with the Garmin RDS unit and the TomTom units I use, the BNC socket makes it easy to remove to transplant the kit to another car as I use Hire cars with work quite often - Mike
PaulB2005
PostPosted: Wed Apr 09, 2008 1:15 pm    Post subject: Reply with quote
Thanks. I'll have a think about it....
ijhill
PostPosted: Wed Apr 09, 2008 3:07 pm    Post subject: Reply with quote
The link I gave was the only demountable one I could find that covered all of the fm spectrum, as stated the mini scan doesn't. The aerial should be slightly longer than the mini scan; the price is around the same.
I now pick up a signal on my drive, previously I had to drive a couple of miles to civilisation before I got any traffic.
PaulB2005
PostPosted: Sat Apr 12, 2008 11:40 pm    Post subject: Reply with quote
Parts now ordered from Rocket Radio. Maplin were out of stock of antenna.
I noticed on this thread davawt states
it was just fill the brass bit with solder then heat up as I offer the wire in.
Is that the easiest way to solder the wire to the brass bit? I've never got round to soldering before and only need to solder one cable to one connector. I have access to the hardware, just no practise. I'm one of those people that is totally useless until I've seen / done something once in front of me and then i get it....... Stupid i know... Embarassed
PostPosted: Sun Apr 13, 2008 7:12 am    Post subject: Reply with quote
The alternative is to get the crimp type connector but the crimping tools cost a small fortune, for a good reliable connection soldering the joint is best - Mike
PaulB2005
PostPosted: Sun Apr 13, 2008 2:15 pm    Post subject: Reply with quote
I found a PDF on a website that shows how to dismantle the plug / socket and how to solder using the solder hole, then put the plug / socket together.
This is it
I'll have to wait for my order to arrive from Rocket Radio and then i'll either borrow or buy a soldering iron....
PaulB2005
PostPosted: Tue Apr 15, 2008 12:53 pm    Post subject: Reply with quote
Antenna arrived from RocketRadio and so did some random bit i don't recognise.
I ordered
and got a BNC Female Coupler (like this) and a BNC plug but i don't think it's the right one..... Crying or Very sad
edit: This is what i was sent with the F-F coupler....
Wife is shopping and has just received an order for one of these
22.124 (26 Dec 24)
