Pocket GPS World :: View topic - iPaq 316 The Green Mile
jordand
PostPosted: Tue Apr 08, 2008 2:51 pm    Post subject: iPaq 316 The Green Mile Reply with quote
Is it possible to change the color scheme of iPaq 316(310), and especially the green colour of the route? Rolling Eyes Rolling Eyes
I'd also like to know if there's a way to install offroad or topo maps on this device?
PostPosted: Wed Apr 09, 2008 4:09 pm    Post subject: Reply with quote
The manual I found on-line seems to suggest there is a a day and a night colour scheme. It doesn't seem to mention an option to change it further than that.
Map visualization
The current version of the Travel Companion is primarily intended for land navigation. That is why maps in the Travel Companion look similar to paper roadmaps (when using daytime colors and 2D map mode).
However, the Travel Companion provides much more than regular paper maps can. The look and the contents can be changed.
Daylight and night color schemes
The daylight and night color schemes let you adjust the Travel Companion to the brightness of the environment. Use the daylight and night color schemes accordingly. Daylight colors are similar to paper roadmaps, while the night color schemes use dark tints for large objects to keep the average brightness of the screen low, with carefully selected colors to still keep you informed about all the necessary information on the screen.
You can change between day and night views manually in Settings, or let the Travel Companion do it automatically for you.
TIP: To further enhance the effect of the night color scheme, you can instruct the Travel Companion to decrease the display backlight when the night colors are used. Set the desired backlight levels for both daylight and night modes.
Only mention of maps I found was:
HP navigation software including Western-European maps (iPAQ 314) or Eastern-European maps (iPAQ 316)
Not much help, but the best I found so far.
22.064 (26 Jun 24)
