Pocket GPS World :: View topic - 6010x5 ipaq2210 problem!
gpsidiot
PostPosted: Wed Apr 28, 2004 11:47 am    Post subject: 6010x5 ipaq2210 problem! Reply with quote
Hi all, my initial post seems to have fallen foul of the hacker, so here I go again!
I have a 6010 x5 receiver on an ipaq2210 running tt2 and city maps. It is mounted using a powered mount from seidio.
My car is a Renault scenic, (but I have tried it with the receiver on the roof!)
My problem is, I only receive a signal for 5-10 mins or so before the gps freezes!
If I connect to a laptop in the same car running autoroute all seems fine!!
I am currently running ver 3.01 of gps s/w.
An initial reply yesterday suggested I try ver 2.7, where can I get that from?
Please help before I go totally mad!!!!
PostPosted: Wed Apr 28, 2004 4:34 pm    Post subject: Reply with quote
you can get version 2.07 from our downloads page.
gpsidiot
PostPosted: Wed Apr 28, 2004 5:13 pm    Post subject: Reply with quote
Thanks i will give it a try!
"The difference between intelligence and stupidity is that intelligence has its limits."
gpsidiot
PostPosted: Tue May 04, 2004 9:29 am    Post subject: Reply with quote
I have loaded the driver as suggested, and it does seem to function better, i am ,however, still having the unit lock up on me for no obvious reason. so i will try a hard reset and full reload and try again!
Just in case!!
gpsidiot
PostPosted: Mon May 10, 2004 12:35 pm    Post subject: Reply with quote
Hi all Back again!
Sorry to say that a hard reboot hasn't cured my problems, so any other advise would be welcome!
PostPosted: Mon May 10, 2004 2:31 pm    Post subject: Reply with quote
any chance you can try the 6010 at a friends' machine, or try another GPS receiver with your machine?
gpsidiot
PostPosted: Mon May 10, 2004 2:55 pm    Post subject: Reply with quote
Hi Lutz,
If i run it on my laptop running autoroute it seems fine. It aquires sats almost immediatly, and certainly whilst testing, (about an hour it seems fine!),my instinct tells me its a dodgy s/w load on the ipaq, but having hard reset and reinstalled, i am at a loss to see how i can make any difference to the load!
PostPosted: Mon May 10, 2004 3:23 pm    Post subject: Reply with quote
It must be a 2210 timing issue then. You probably have read about all the issues with the 2210 and TomTom III and the TomTom BT GPS... Did you install the latest ROM for the 2210?
gpsidiot
PostPosted: Mon May 10, 2004 3:40 pm    Post subject: Reply with quote
yes its got the latest Bios, what concerns me somewwhat is mine is the plain old wired type of reciever, so wasn't too sure how relavent the bt postings were.
PostPosted: Mon May 10, 2004 3:57 pm    Post subject: Reply with quote
I think it has more to do with the 2210 than with the receivers. Then again I may be wrong... I am really curious to see someone come up with the real explanation...
gpsidiot
PostPosted: Wed May 12, 2004 3:31 pm    Post subject: Reply with quote
Update.
Following further investigation,
There were 2 different versions of gps listed in programs, so i deleted one. (ensuring i was left with ver 2.07).
I also changed the setting from rikaline to MNEA 4800.
resetting each time.
Having done this i got the reciever to stay "active" for 45 mins or so before locking, A RECORD!
I also found that it stopped cleanly when exited.
More testing followed, which reveald that if you run city maps or navigator, it locks up within 5-10 mins.
If either map was running this seems to prevent the ipaq cclosing the programe cleanly!
So it would seem i am progressing, but to where, at to what end result who can say!!!
gpsidiot
PostPosted: Mon May 17, 2004 7:19 pm    Post subject: Reply with quote
Hi all back again, having re installed the latest Rom version, cleanly loading all the s/w as noted previously, the damned thing still wont function for any length of time!
I must say that having contacted Rikaline for help, it would seem that once they have exhausted their stock replies, the help dries up completely.
I am left with the belief that i have a fundamentally flawed setup, where the individual components appear to work, until they are combined!!
All in all, a very easy way to waste money, AND a whole heap of time!!!
22.063 (19 Jun 24)
