Pocket GPS World :: View topic - Settings (Remove Programs)?
ttrevor
PostPosted: Sun May 09, 2004 8:33 pm    Post subject: Settings (Remove Programs)? Reply with quote
Just had a look at the remove programs screen, programs that are in the storage memory and found
TomTom~GPS ?
TomTom GPS
what does this signify ~ did not see it on TT2 and should there be 2GPS,s
cheers
trevor
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
PostPosted: Sun May 09, 2004 10:20 pm    Post subject: Reply with quote
The ~ was there under TTN2 also, it's a fudge driver which can cause problems with other GPS programs.
ttrevor
PostPosted: Mon May 10, 2004 7:15 am    Post subject: Reply with quote
Thanks for reply Dave,so should they both be there TomTom~GPS and TomTom GPS?
trevor
PostPosted: Mon May 10, 2004 7:24 am    Post subject: Reply with quote
You may only see TomTom ~ GPS now, but don't worry if you don't see TomTom GPS as uninstalling TomTom ~ GPS just uninstalls the fudge driver.
ttrevor
PostPosted: Mon May 10, 2004 7:52 am    Post subject: Reply with quote
Dave both are on the add/remove screen so should i remove TomTom~GPS and just leave TomTom GPS
trevor
PostPosted: Mon May 10, 2004 9:25 am    Post subject: Reply with quote
Correct, this is what has worked for me time and time over and just recently with 3.01. You'll probably find the TomTom ~ GPS also higher up on the list.
ttrevor
PostPosted: Mon May 10, 2004 10:06 am    Post subject: Reply with quote
Dave did as you said and removed TomTom~GPS to no avail,all it did was to freezeup my pda, so i did a restore and got every thing back except Bluetooth , when i try to start Bluetooth i get the message
Bluetooth could not be initialized BTTrayCE
any ideas
trevor
ttrevor
PostPosted: Mon May 10, 2004 11:01 am    Post subject: Reply with quote
All sorted, Embarassed except that TomTom~GPS still on the add/remove screen , i will leave well alone as the system is working great, but i am a compulsive fiddler ,i think thats the only way to learn, Happy
Thanks once again Dave for your help Thumbs Up
rgds
trevor
DavidW
PostPosted: Mon May 10, 2004 12:39 pm    Post subject: Reply with quote
At some point in the past, TomTom changed from declaring their application to the Application Manager as "TomTom GPS" to "TomTom ~ GPS". If you didn't uninstall previous versions before installing new ones, you may have both in your "Remove Programs" list.
My guess would be that "TomTom ~ GPS" will do the two stage uninstall of a recent version, and "TomTom GPS" may do something weird (and can possibly be edited out of the Registry, but that may also have side-effects). However, the behaviour here is a little undefined. If an uninstall of "TomTom ~ GPS" doesn't force a soft reset, I'd expect things Bluetooth to be weird, and a soft reset would solve it. Usually the first uninstall of a recent version of TomTom GPS (which unhooks the Bluetooth driver) forces a soft reset, and usually the second one (which removes recent versions of TomTom GPS completely) does as well.
Because of the "in use" nature of the Bluetooth driver and the change of application name, it's probably better to remove one version of TomTom GPS completely from the Pocket PC before installing another. "Remove Programs" offers a fairly easy way to do this without having to wait for ActiveSync to fire up potentially three times (twice to remove the old version and a third time to install the new version).
ttrevor
PostPosted: Mon May 10, 2004 1:04 pm    Post subject: Reply with quote
Hi Dave thanks for that, but as i said in my last post i will leave well alone ,unless you think one should be removed,as at present its working no problems at all? i dont want to playaround to much Happy
cheers trevor
DavidW
PostPosted: Mon May 10, 2004 2:13 pm    Post subject: Reply with quote
I think you have the right attitude - if it works don't "fix" it!
22.063 (19 Jun 24)
