Pocket GPS World :: View topic - POI Warning question
lencuff
PostPosted: Thu Apr 03, 2008 5:53 pm    Post subject: POI Warning question Reply with quote
Is there any easy way to set a load of POI warning up to be the same? Obviously talking speed cams in this case. I have just had to reinstall TT6 and all the warning have defaulted back from how I had them set. Do I have to go into every one individually and set them back up again?
Cheers,
Len
falkirk81
PostPosted: Sun Apr 06, 2008 4:53 am    Post subject: Reply with quote
There is no easy way to set up all the different cameras with the same warning tone. Only way around it would be to download the database thats got just the single poi camera set, then you only have to set the sounds up once. Drawback is that its one warning for any type of camera, from mobile to specs, no difference in icon or warning!
Tomtom GO 1005 LIVE
iPhone 12
Oldboy
PostPosted: Sun Apr 06, 2008 6:53 am    Post subject: Re: POI Warning question Reply with quote
Did you have a Backup of the Device before you did the re-install?
If you didn't have a Backup, then you will have to do each one again. Sad
If you did, then in the Map Folder will be a .cfg File. If it's a V6 Map it will be called MapSettings.cfg and this should be copied to the current Map Folder.
Though why it should change it if you've only re-installed the Software, I don't know. Unless you re-installed the Maps as well.
22.064 (26 Jun 24)
