MobileMavs Occasional Visitor
Posted: Fri Apr 04, 2008 11:12 pm Post subject: Wher am I Point on Tom Tom Go 300 |
Hi there,
I recently downloaded a software update on my TTG 300 and was very happy as it had a menu command which was 'where am I' and an information icon which would direct me to the nearest poi eg garage/doctors surgery etc. I believe that there may even have been a medical emergency icon on there. Trouble is it's not been available to me now for several weeks after a further software download. Does anyone know where I can get this from ?
I run a TTG 300 on version 7.162
Many thanks in anticipation |
Posted: Sat Apr 05, 2008 9:07 am Post subject: |
The missing icons can be found via the "HelpMe" button on page one of the menu, if this is missing you must have installed a custom menu, look in the SdkRegistry folder for a file called tomtom.mnu re-name this to tomtom_old.mnu your HelpMe menu should now reappear.
It is not possible to run a custom menu and have access to HelpMe and MapShare at the same time - Mike |
Posted: Sat Apr 05, 2008 1:38 pm Post subject: Where am I Icons |
Hi Mike,
Thanks for your reply - but I've tried that it it still doesn't activate the green help me icons. Initially the mnu file wasn't found in the sdk registry - only the speed camera capture icon, but I've subsequently put it in that folder. What else could I try ? Many thanks in anticipation |
Posted: Sat Apr 05, 2008 1:41 pm Post subject: |
If you take everything out of the SdkRegistry folder (store it safe on the PC so you can put it back again if you want) then the icons will reappear. Any custom menu or third party add on such as POICapture will make the HelpMe and MapShare icons do a disappearing act - Mike |
Posted: Sat Apr 05, 2008 2:05 pm Post subject: Wher am I Point on Tom Tom Go 300 |
Brilliant Mike ! You've solved it thankyou so much ! |
