jordand Occasional Visitor
Posted: Thu Apr 03, 2008 8:34 am Post subject: iPaq 316 Third Party Apps |
Need help on finding and installing Total Commander and other applications on my iPaq 316.
I tried many times with the TC, but message appears that some components are missing... |
Posted: Thu Apr 03, 2008 8:44 am Post subject: |
Quote: | Need help on finding and installing Total Commander |
Where have you got copies from in the past? |
Posted: Thu Apr 03, 2008 8:46 am Post subject: |
Quote: | but message appears that some components are missing... |
What is the exact message? |
Posted: Thu Apr 03, 2008 3:30 pm Post subject: |
http://ghisler.ch/board/viewtopic.php?t=16509
Tried the first link, recommended for most users.
Once installed under ipaq/os/games/tc I unzip the cecmd.arm in the same folder and than rename the files accordingly.
When I open the games folder of the device I can see the new CECMD button but instead of opening the TC a message is displayed saying "Cannot find "cecmd" (or one of its components).Make sure the path and filename are correct and that the required libraries are available." |
Posted: Thu Apr 03, 2008 3:59 pm Post subject: |
All i can say is that appears to be a Beta or pre-release version. The latest stable release is here |
Posted: Thu Apr 03, 2008 5:46 pm Post subject: |
Is it possible that I do something wrong?I first install the TC on my ipaq and than extract the cab. file in the same folfer, after which I rename the files.
Anyway, after doing so I got the same message for missing components. |
Posted: Fri Apr 04, 2008 4:25 pm Post subject: |
jordand wrote: | Is it possible that I do something wrong?I first install the TC on my ipaq and than extract the cab. file in the same folfer, after which I rename the files.
Or could this happen due to an Active Sync problem, because everytime I install the TC a sign appears that the program will be installed the next time the device is connected to the computer.
In fact when I open Active Sync it does not recognize the device although it is connected.
Doesn't have to be that complicated... |
lucian777 Occasional Visitor
Posted: Fri May 02, 2008 8:39 am Post subject: ipaq |
1.download the cab for arm version
2.extract the cab on you desktop pc ( new folder) find the largest file
3.rename the file to CElauncher.exe
4.copy CElauncher.exe to the root of your sd card
5.insert the sd card into ipaq
6.soft reset --- boot into the ce desktop
or download my version and put it in the root of your sd
http://www.fileshare.ro/526397415.12 |
