Pocket GPS World :: View topic - lizprompts 22050 caamera voices not working with app 7.162
Goto page Previous  1, 2
jason_ob
PostPosted: Sun Mar 30, 2008 11:34 am    Post subject: Reply with quote
Agreed! not normal at all. Fortunatly for me I'm not a trucker and don't drive for a living so only need TT on day's out, but this seems like a bug in the new software, which could be a problem for others.
PostPosted: Mon Mar 31, 2008 7:31 pm    Post subject: Reply with quote
As you are on v7 software, you can always use the alternative method of putting all your warning sound .ogg files into the "sounds" folder on the TomTom. Then you can select them from the normal sound effects menu.
The only problem with this method is that with the default naming system PGPSW use for the camera files, you can't easily see which sound file you are choosing as the names are so long the important bit gets cut off the display.
Either do it by trial and error, or you can rename the files to put the speed/camera type at the front of the names, as they do not need to match the ov2 data files with this method.
kestreluk
PostPosted: Tue Apr 01, 2008 8:42 am    Post subject: Reply with quote
Hi Andy I tried this! I transferred the files as suggested to to the sounds folder and went throught the process off adding all warnings all seemed to work OK! GREAT! until I went out and all warnings were police siren no Liz
Evil or Very Mad
I have now copied a previous version of my mapsettings.cfg and have yet to try that on road.
Oldboy
PostPosted: Tue Apr 01, 2008 11:14 am    Post subject: Reply with quote
Try it using a Route past a known camera and run in Demo Mode. Use Demo speed less than 300%.
kestreluk
PostPosted: Fri Apr 04, 2008 11:06 am    Post subject: Reply with quote
Hi thanks for the advice reloading the old MapSettings.cfg all warnings now appear to be fully working. thanks again
Keith
Page 2 of 2
22.064 (26 Jun 24)
