Pocket GPS World :: View topic - Help which directory to transfer the Pois files.
sunseeker888
PostPosted: Sun Mar 30, 2008 2:09 pm    Post subject: Help which directory to transfer the Pois files. Reply with quote
Hi Folks
Help, I have downloaded the POIS for UK. I am newbie. Where shall I shall insert the unzip in which directory. I have 2 maps on my sd card, UK and Europe map.
I assume it will be in UK folder, but which directory to transfer the files.
cheers
Tomtom Go 950 Live
PostPosted: Sun Mar 30, 2008 2:49 pm    Post subject: Reply with quote
You have downloaded a file called POIs.zip.
You must unzip this and it will give you two files, - newPOI.bmp and newPOI.ov2.
You copy both these files into the map folder (directory) you wish to use - Great Britain map. They do NOT go into a folder inside the map folder.
sunseeker888
PostPosted: Mon Mar 31, 2008 12:04 pm    Post subject: Reply with quote
Thanks a lot for the reply
Tomtom Go 950 Live
PostPosted: Mon Mar 31, 2008 7:10 pm    Post subject: Reply with quote
Hang on a sec..
Dennis is coorrect when he says:
But then goes onto say:
Great Britain map.[/quote]
That's not the whole answer.
You put the POI files into the map folder of ANY and EVERY map you want to use them with.
In other words, if your Europe map covers the UK, and you ever intend to use it while in the UK, then your UK POI files need to be copied into that map folder TOO.
So my question is... why are you still using a 'UK only' map if you have got a (presumably) newer one that covers the whole of Europe, including the UK?
PostPosted: Mon Mar 31, 2008 7:31 pm    Post subject: Reply with quote
Both maps are v715, Andy, so I assumed he is only using GB for performance benefits, AND if he goes off into Europe he won't need UK POIs because they won't show up in France etc.
PostPosted: Mon Mar 31, 2008 11:24 pm    Post subject: Reply with quote
Performance benefits?
If both are v715 I thought the UK would be the same on both?
Even the "curves v. straight lines" compression issue I thought was the same on these two.
PostPosted: Tue Apr 01, 2008 8:03 am    Post subject: Reply with quote
Don't ask me! I wouldn't have both maps myself. But I thought it runs faster if you only use a small regional instead of a large continental, or am I wrong? I'm sure I saw it once, before I started getting age-related memory problems. On a GO300, he has to have BOUGHT both maps and there's got to be a reason for that.
(But just for interest, I have WE v710 on a 720 and W&CE v710 on the 920 and occasionally I do get different nav instructions from them).
GPS_fan
PostPosted: Tue Apr 01, 2008 8:32 am    Post subject: Reply with quote
Ah, didn't shadamehr or somebody say that they'd compared the maps.
I think the conclusion was quality of mapping -
the W&CE maps have greater compression in order to save them onto a specific sized SD card, so the quality is marginally poorer
the WE maps contain slightly less data and don't require such great compression, so the quality is marginally better
Unless you're travelling to Central Europe, I would have thought the WE maps ought to be more appropriate
Andy
22.105 (30 Oct 24)
