Pocket GPS World :: View topic - Can't connect to Tomtom Home
jkm
PostPosted: Wed Mar 19, 2008 5:45 pm    Post subject: Can't connect to Tomtom Home Reply with quote
I have a Tomtom700 and vista pc.
When connected to pc the700 shows in My Computer and is fine for access.
But it wont connect to Tomtom home latest version,i looked on there website downloaded the fix "home_images" unzipped it and placed the folder in the root directory of the Tomtom still no joy, any ideas ?
jkm
jkm
PostPosted: Thu Mar 20, 2008 12:06 pm    Post subject: Reply with quote
Anyone else having problems with Vista and Tomtom home ?
jkm
PostPosted: Thu Mar 20, 2008 12:55 pm    Post subject: Reply with quote
Have just looked at the TT help on the subject on This Page, and from what you said:
TT says:
Copy the unzipped folder home_images to the root directory of your TomTom device.
Did you copy a Folder called home_images, and the files it contains, to the Root of the Drive?
TT Via 135 App 12.075: Europe Map v1145
jkm
PostPosted: Thu Mar 20, 2008 2:31 pm    Post subject: Reply with quote
TT says:
Thanks Richard yes i did, I unzipped it and trnsferred the folder with the files still in it to the root of the tomtom, the folder home_images is showing there with all the files inside.
Do you think it's possible that the folder should be empty the files in it cut and pasted direct to the root directory ?
jkm
PostPosted: Thu Mar 20, 2008 2:35 pm    Post subject: Reply with quote
No it works fine here, have you tried a different cable? and also check if the TomTom can be seen in "Computer" on the PC, this way we will know if the problem is a general connection issue or specific to home - Mike
jkm
PostPosted: Thu Mar 20, 2008 2:44 pm    Post subject: Reply with quote
Thanks mikealder yes it is specific to tomtom home latest version, through my computer i can see the files and transfer both ways.
jkm
bensonboo
PostPosted: Thu Mar 20, 2008 4:42 pm    Post subject: Reply with quote
jkm wrote:
Oldboy wrote:
TT says:
Thanks Richard yes i did, I unzipped it and transferred the folder jkm
I'm not using Vista, but is this not a contradiction of the instructions?
rugrat2
PostPosted: Thu Mar 20, 2008 4:47 pm    Post subject: Reply with quote
does it say COPY THE UNZIPPED FOLDER...
Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go..
PostPosted: Thu Mar 20, 2008 6:19 pm    Post subject: Reply with quote
Yes.
I reasoned that it means the Folder that the UnZip programme creates and has placed the files in.
Would have read better if it had said 'Copy the new Folder, 'home_images', to the Root of the Device.
Chris_penmoor
PostPosted: Mon Mar 31, 2008 5:00 pm    Post subject: I'm having the same trouble Reply with quote
I am having the same trouble with a Tomton One 1st edition, rev 5.410.
I've tried this on my Mac and XP laptop and its just the same. the computer sees the device and allows me to put the home_images folder in the root directory but Tomtom home still doesn't see the device. I want to update the software but can't, is there a manual way?
There is some confusion with the downloaded zip file it create a home images folder not a home_images as described but I tried calling the folder both names and still no joy.
griffo86
PostPosted: Mon Mar 31, 2008 5:15 pm    Post subject: Reply with quote
I had trouble with HOME on Vista too a while back, errors popping up all over the place. Even TomTom couldn't work out what was going on. I reverted back to XP after a while, due to a slow Vista setup and all is well.
PostPosted: Mon Mar 31, 2008 5:50 pm    Post subject: Reply with quote
Chris, if you go to Oldboys web site (click the WWW button in the post directly above yours) you will be able to download an earlier version of v6 software for your device, within the download is a readme file containing the instructions for a manual upgrade.
Once the new files are loaded to the device TomTom will see the device and look for any newer updates that might be available. As always back up the device to the PC BEFORE doing any of the above - Mike
PostPosted: Mon Mar 31, 2008 5:50 pm    Post subject: Re: I'm having the same trouble Reply with quote
Try upgrading to V6.560 first.
Just make sure you have an Explorer Backup before using it.
There's a Text File on how to load it in the Zip File.
Chris_penmoor
PostPosted: Mon Mar 31, 2008 10:15 pm    Post subject: Thanks Reply with quote
Its all sorted now I found a place to download Tomtom Home Version 1.3.2.
And then upgraded from there, but thanks anyway once a the latest version on software on the Device you can then upgrade Tomtom Home too.
I found the old version at the filefactory. http://software.filefactory.com/Mac/TomTom_HOME_1-3-200.html
But thanks for the other recommendations.
