Pocket GPS World :: View topic - nuvi 660 new out of box
BONDENO
PostPosted: Mon Mar 31, 2008 4:06 pm    Post subject: nuvi 660 new out of box Reply with quote
i have it new out of box poi enabled they only show when calculating route and then vanish when route calculated.Loads of speed cams not showing it cant be that old am sure is it faulty?
PostPosted: Mon Mar 31, 2008 4:26 pm    Post subject: Reply with quote
you mean garmin's own camera database? from my experience they're not as up to date as ours...
BONDENO
PostPosted: Mon Mar 31, 2008 4:44 pm    Post subject: Reply with quote
Hi No The default factory cams i bet 75% are missing.Its also the poi they dont show only when calculating route when calculated they dissapear.
philpugh
PostPosted: Mon Mar 31, 2008 6:00 pm    Post subject: Reply with quote
If you wnat to see the POIs then you need to be zoomed in quite close. In 2D mode this is to the 300ft scale or closer. This is done to prevent the map getting very cluttered.
Phil
BONDENO
PostPosted: Thu Apr 03, 2008 9:07 pm    Post subject: Reply with quote
Yep done that and they still dont show the map zooms out by itself when i start driving there is nothing i can do to stop it
22.064 (26 Jun 24)
