Pocket GPS World :: View topic - Nuvi 7xx - Removing Routes from the unit.
PaulB2005
PostPosted: Mon Mar 31, 2008 9:46 am    Post subject: Nuvi 7xx - Removing Routes from the unit. Reply with quote
I was playing around with the Routes feature by making a route on MapSource and then loading it to the Nuvi 760.
Once you've done that you have to goto Tools, My Data and then Import Route from File. Then the Route appears under Where To?, Routes.
I can remove the Routes by going to Tools, My Data and Delete Routes but this leaves them still listed under the Import Route From File screen.
Does anyone know how to clear that list or where the routes waiting to be imported are held on the Nuvi? I've got loads of useless routes in that file!!!
PaulB2005
PostPosted: Mon Mar 31, 2008 10:08 am    Post subject: Reply with quote
I've found if you send the data to an SD Card if creates a folder called Garmin\GPX and file called userdata.gpx but i can't find this on the main unit (which didn't have a SD card in at the time)
PaulB2005
PostPosted: Mon Mar 31, 2008 10:10 am    Post subject: Reply with quote
Sorted. Found it was adding a file called Temp.gpx under Garmin/GPX. The fact it was called userdata.gpx on the SD Card was throwing me.
Delete it and the routes have gone.
22.064 (26 Jun 24)
