Pocket GPS World :: View topic - [v7] New PGPSW CoPilot 7 Camera Database Format!
Goto page Previous  1, 2, 3
Mikbol
PostPosted: Tue Jan 08, 2008 6:51 pm    Post subject: Safety Camera Alerts Reply with quote
Hi MaFt,
Please can we have the option to download a single file of safety cameras for Copilot 7. The only way I can get the system to work properly, showing all cameras with speed limits as appropriate is to combine all the files and call it safetycam.csv so this would save me some time. It might be an idea to set the speed limit for red light cameras to 99mph or similar to help differentiate them from the rest.
All the best
Mike
PostPosted: Tue Jan 08, 2008 10:18 pm    Post subject: Reply with quote
it works fine on mine having them as consolidated by type but i can look at creating a single file set after the next release.
got a fw bigger fish to sort out first though!
AndyRoss
PostPosted: Wed Mar 26, 2008 4:47 pm    Post subject: Reply with quote
Can I confirm that I also needed to combine all the files and rename to safetycam.cvs before the cameras worked correctly.
PostPosted: Thu Mar 27, 2008 6:00 pm    Post subject: Reply with quote
i'll try get one done for next release
LandRocket
PostPosted: Sun Mar 30, 2008 9:07 am    Post subject: CoPilot 7 and CSVs Reply with quote
Not sure if this is of help to anybody, but I was messing about with CP7 this morning in an attempt to figure out why the alerts only seem to be occurring on the Gatso cameras.
What I discovered is that if you load any other POIs in CSV format (ie non camera CSVs) it appears to break the camera database.
I re-downloaded my extra POIs from the free POI database here, but instead asked for them in OV2 format, and loaded them AFTER putting on the CSV speedcams (ie put CSV cameras on, load CP, close CP, put on OV2 POIs, load CP)
I then asked CP7 for a route from my home address into the city centre, where I know there's at least 3 plotted mobile cameras. Certainly on the route demo, they all appeared, complete with speed warning.
Hoping this helps others
LR
AndyRoss
PostPosted: Wed May 21, 2008 8:16 pm    Post subject: Reply with quote
When will the Single File Co-Pilot 7 cameras be released. It's a bit of a pain having to copy them into one file each time?
It's also mentioned in another post about trialling a file with headers? How is this going?
Andrew
DingleRoad
PostPosted: Mon Jun 30, 2008 11:59 am    Post subject: Reply with quote
The Co-Pilot 7 is driving me mad.
I've deleted all the AO files and downloaded the latest csv files to my desktop.
Then I've gone to storage/Copilot/EU/save and copied and pasted to this file the csv and bitmap files from PGPS world.
Then I've restarted CP 7 on my PDA. Now if I look in the save file again I see the AO files have returned ...is this correct ?
I've selected Safety camera alert enable at 500 yds but it seems very arbitary about which ones to warn me about !
scarymonkey
PostPosted: Mon Jun 30, 2008 1:03 pm    Post subject: Reply with quote
Yes. The CSV files are parsed and converted back into the AO files when you launch CP7
I have seen this as well. Sometimes it is because CP7 uses heading data which could be wrong in the database. Other times it is just CP7 being annoying and not aleritng correctly. I found the latest version of the application improves this considerably though.
DingleRoad
PostPosted: Mon Jun 30, 2008 5:04 pm    Post subject: Reply with quote
OK thanks very much SM.
Might seem a dumb question, but how do I check my latest application....on Co-Pilot central ??
I would quite like to get rid of all the POI's in CP 7 and use the PGPS world POI's is this possible ?
Many thanks
scarymonkey
PostPosted: Mon Jun 30, 2008 11:46 pm    Post subject: Reply with quote
In settings there is an 'about CoPilot' button. Clicking this shows a version numbers as well as info on the current maps and your product key.
TBH POI handling in CP is very poor. I'm not aware of a way to remove the built in ones fully, although you can selectively turn the reporting of them off from the POI menu in Settings.
AFAIK all user POIs are added Custom POI heading and the choice of icons is limited (you cannot easily use your own).
I sent ALK a suggestion to improve POI handling but they haven't even given me a response (I sent it over a month ago now)
PostPosted: Tue Jul 01, 2008 10:07 am    Post subject: Re: Safety Camera Alerts Reply with quote
Mikbol wrote:
Hi MaFt,
now added - sorry for the delay!
Page 3 of 3
22.113 (20 Nov 24)
