Pocket GPS World :: View topic - Flashing RED X
Flashing RED X
tuftyjack
PostPosted: Fri Mar 28, 2008 2:14 pm    Post subject: Flashing RED X Reply with quote
After downloading an update of Mapshare and gpsfix from Home to my TTG520, the flashing "RED X do not remove TTG" continued to flash along with both icons for TTG internal memory and SD card. After 10 minutes I removed the unit and, glad to say, it worked fine. Plugged in again and the flashing was still there so I did a reset, but to no avail. What has happened and how do I fix it, Please ?????
Toneloc427
PostPosted: Fri Mar 28, 2008 2:16 pm    Post subject: Reply with quote
What computer OS are you using? Have you updated via home successfully in the past?
tuftyjack
PostPosted: Fri Mar 28, 2008 4:05 pm    Post subject: Flashing RED X Reply with quote
I am using Vista Home Premium and have downloaded loads of updates with no problems.
tuftyjack
PostPosted: Fri Mar 28, 2008 4:12 pm    Post subject: Flashing Red X Reply with quote
I have had a senior moment. The RED X doesn't flash, it's the 2 icons for internal memory and SD card that flash continually whilst the RED X is still. It is still there today after further download of Mapshare and Quickfix.
Oldboy
PostPosted: Fri Mar 28, 2008 5:59 pm    Post subject: Reply with quote
That means 'don't remove I'm doing something'.
If you use Safely Remove Hardware, or Disconnect Device, it should finish it's task and cause the unit to reboot.
tuftyjack
PostPosted: Sat Mar 29, 2008 11:32 am    Post subject: Flashing RED X Reply with quote
Connected today and the problem has gone. TCHHH Computers!!!!!
22.064 (26 Jun 24)
