tuftyjack Occasional Visitor
Posted: Fri Mar 28, 2008 2:14 pm Post subject: Flashing RED X |
After downloading an update of Mapshare and gpsfix from Home to my TTG520, the flashing "RED X do not remove TTG" continued to flash along with both icons for TTG internal memory and SD card. After 10 minutes I removed the unit and, glad to say, it worked fine. Plugged in again and the flashing was still there so I did a reset, but to no avail. What has happened and how do I fix it, Please ????? |
Toneloc427 Regular Visitor
Joined: Feb 01, 2007 Posts: 143 Location: New England, USA
Posted: Fri Mar 28, 2008 2:16 pm Post subject: |
What computer OS are you using? Have you updated via home successfully in the past? |
Posted: Fri Mar 28, 2008 4:05 pm Post subject: Flashing RED X |
I am using Vista Home Premium and have downloaded loads of updates with no problems. |
Posted: Fri Mar 28, 2008 4:12 pm Post subject: Flashing Red X |
I have had a senior moment. The RED X doesn't flash, it's the 2 icons for internal memory and SD card that flash continually whilst the RED X is still. It is still there today after further download of Mapshare and Quickfix. |
Oldboy Pocket GPS Moderator
Posted: Fri Mar 28, 2008 5:59 pm Post subject: |
That means 'don't remove I'm doing something'.
If you use Safely Remove Hardware, or Disconnect Device, it should finish it's task and cause the unit to reboot. _________________ Richard
Posted: Sat Mar 29, 2008 11:32 am Post subject: Flashing RED X |
Connected today and the problem has gone. TCHHH Computers!!!!! |
