Pocket GPS World :: View topic - TTG520 - lost 'bongs' for cameras/can't install map changes
ianfreeman
PostPosted: Thu Mar 27, 2008 3:50 pm    Post subject: TTG520 - lost 'bongs' for cameras/can't install map changes Reply with quote
The warning sound when approaching a camera has suddenly disappeared from my TTG520. And, although Map Share changes download OK via Home, I get a message that they cannot be installed. Should I try a full reset or is there an easier solution? Many thanks for any advice.
burren
PostPosted: Thu Mar 27, 2008 4:12 pm    Post subject: Reply with quote
I lost my camera warning sounds (not the cameras) after the recent 7.480 update. Got them back by going to "tt safety cameras" then "disable alerts" then "re-enable alerts" --sounds back on. Worth a try !!
ianfreeman
PostPosted: Thu Mar 27, 2008 4:26 pm    Post subject: Reply with quote
[quote="burren"]I lost my camera warning sounds (not the cameras) after the recent 7.480 update. Got them back by going to "tt safety cameras" then "disable alerts" then "re-enable alerts" --sounds back on. quote]
Many thanks Burren - I've done that and will see if it helps when I next go out. My problems started when I downloaded the new software too! Evil or Very Mad
burren
PostPosted: Thu Mar 27, 2008 4:56 pm    Post subject: Reply with quote
Try it in demo mode on a route you know has cameras. It might give you a clue as to whether it might work !!
PostPosted: Thu Mar 27, 2008 5:31 pm    Post subject: Re: TTG520 - lost 'bongs' for cameras/can't install map chan Reply with quote
Sorry to use you as an example, but this shows how useful it is if everyone can give as much information about what happened or what you did just before a problem appeared!
If we didn't know you'd just gone to the latest software, we would have probably gone off on a totally different line of investigation. Smile
ianfreeman
PostPosted: Thu Mar 27, 2008 5:43 pm    Post subject: Re: TTG520 - lost 'bongs' for cameras/can't install map chan Reply with quote
Yes, point taken. Stupid of me. The problem is I can see the cameras but can't 'hear' them so will have to wait until I travel to see if the reset has worked. The problem with installing Map Share updates remains, though... Sad
PostPosted: Thu Mar 27, 2008 5:55 pm    Post subject: Reply with quote
As Burren said, no need to wait, just run a "demo" past a camera you know.
Menu p2 "Prepare Route" (known as Advanced A-B planning on older software) set the 'from' and 'to' points using "point on map" to go past a camera. Once it has calculated the route, tap "details" and then "show route demo". Set speed around 200% (no higher then 300%) and listen for the sounds.
EDIT: The above all assumes you are using the PGPSW speed cam database. I don't think the TomTom-supplied one works in Demo mode. (but you say you can "see" the cameras so I think it must be the PGPSW one).
I think the Mapshare issue is possibly also down to this rubbish software version.
Can you revert back to your previous set-up? Please tell us you did a backup before you updated it....
ianfreeman
PostPosted: Thu Mar 27, 2008 6:07 pm    Post subject: Reply with quote
I think the Mapshare issue is possibly also down to this rubbish software version. Can you revert back to your previous set-up? Please tell us you did a backup before you updated it....
Great - did the demo and it works fine - the bongs are back! Many thanks.
I was stupid enough not to do a back-up! Urgh. Sad
PostPosted: Thu Mar 27, 2008 6:10 pm    Post subject: Reply with quote
Now's the time then.... Smile
