ianfreeman Occasional Visitor
Posted: Thu Mar 27, 2008 3:50 pm Post subject: TTG520 - lost 'bongs' for cameras/can't install map changes |
The warning sound when approaching a camera has suddenly disappeared from my TTG520. And, although Map Share changes download OK via Home, I get a message that they cannot be installed. Should I try a full reset or is there an easier solution? Many thanks for any advice. |
burren Occasional Visitor
Posted: Thu Mar 27, 2008 4:12 pm Post subject: |
I lost my camera warning sounds (not the cameras) after the recent 7.480 update. Got them back by going to "tt safety cameras" then "disable alerts" then "re-enable alerts" --sounds back on. Worth a try !! |
Posted: Thu Mar 27, 2008 4:26 pm Post subject: |
[quote="burren"]I lost my camera warning sounds (not the cameras) after the recent 7.480 update. Got them back by going to "tt safety cameras" then "disable alerts" then "re-enable alerts" --sounds back on. quote]
Many thanks Burren - I've done that and will see if it helps when I next go out. My problems started when I downloaded the new software too!  |
Posted: Thu Mar 27, 2008 4:56 pm Post subject: |
Try it in demo mode on a route you know has cameras. It might give you a clue as to whether it might work !! |
Andy_P Pocket GPS Moderator
Posted: Thu Mar 27, 2008 5:31 pm Post subject: Re: TTG520 - lost 'bongs' for cameras/can't install map chan |
ianfreeman wrote: | The warning sound when approaching a camera has suddenly disappeared |
ianfreeman wrote: | My problems started when I downloaded the new software too! |
Sorry to use you as an example, but this shows how useful it is if everyone can give as much information about what happened or what you did just before a problem appeared!
If we didn't know you'd just gone to the latest software, we would have probably gone off on a totally different line of investigation.  |
Posted: Thu Mar 27, 2008 5:43 pm Post subject: Re: TTG520 - lost 'bongs' for cameras/can't install map chan |
Andy_P2002 wrote: |
Yes, point taken. Stupid of me. The problem is I can see the cameras but can't 'hear' them so will have to wait until I travel to see if the reset has worked. The problem with installing Map Share updates remains, though...  |
Posted: Thu Mar 27, 2008 5:55 pm Post subject: |
As Burren said, no need to wait, just run a "demo" past a camera you know.
Menu p2 "Prepare Route" (known as Advanced A-B planning on older software) set the 'from' and 'to' points using "point on map" to go past a camera. Once it has calculated the route, tap "details" and then "show route demo". Set speed around 200% (no higher then 300%) and listen for the sounds.
EDIT: The above all assumes you are using the PGPSW speed cam database. I don't think the TomTom-supplied one works in Demo mode. (but you say you can "see" the cameras so I think it must be the PGPSW one).
I think the Mapshare issue is possibly also down to this rubbish software version.
Can you revert back to your previous set-up? Please tell us you did a backup before you updated it.... |
Posted: Thu Mar 27, 2008 6:07 pm Post subject: |
Andy_P2002 wrote: | Set speed around 200% (no higher then 300%) and listen for the sounds.
I think the Mapshare issue is possibly also down to this rubbish software version. Can you revert back to your previous set-up? Please tell us you did a backup before you updated it.... |
Great - did the demo and it works fine - the bongs are back! Many thanks.
I was stupid enough not to do a back-up! Urgh.  |
Posted: Thu Mar 27, 2008 6:10 pm Post subject: |
Now's the time then....  |
