Posted: Sun Feb 10, 2008 7:43 pm Post subject: |
sunseeker888
It might be best if you started a new thread of your own. Please also mention the make and model sat nav you have. |
GTE Occasional Visitor
Posted: Mon Mar 24, 2008 10:57 pm Post subject: Reverse |
Hmmm Directional Cameras... I guess I will then not get a warning of I am reversing up the motorway :|
Or the will soon catch me in a camera when I try to outrun the police on the wrong side of the motorway and not get warned about cameras. |
BadBoyVTEC Occasional Visitor
Posted: Tue Apr 01, 2008 5:45 pm Post subject: |
on my mio c510 some of the cams seem not to face in the correct direction.
oh well whatever |
odonoghue Lifetime Member
Posted: Thu Apr 03, 2008 2:43 pm Post subject: Road angel |
Is the road angel unit able to take the pgps database |
Andy_P Pocket GPS Moderator
Posted: Thu Apr 03, 2008 5:06 pm Post subject: Re: Road angel |
odonoghue wrote: | Is the road angel unit able to take the pgps database |
Unfortunately it would seem not...
See:
Road Angel Users
or
Road Angel |
M8TJT The Other Tired Old Man
Posted: Thu Apr 03, 2008 7:21 pm Post subject: |
BadBoyVTEC wrote: | on my mio c510 some of the cams seem not to face in the correct direction.
oh well whatever |
Are the ones that are pointing the wrong way from the Mio database, the PGPSW database or ones that you have entered manually?
If from PGPSW perhaps you could find the cam number on the submissions map and let us know which one(s) are the problem. |
Posted: Tue Apr 08, 2008 5:13 pm Post subject: |
PGPSW db obviously ;) I am pretty lazy so I will find some next time I come across them. It is also kinda awkward hitting the "Add Cam" button while your driving along. |
Posted: Thu Apr 10, 2008 1:22 pm Post subject: |
BadBoyVTEC wrote: | It is also kinda awkward hitting the "Add Cam" button while your driving along. |
I manage just by putting the coke/hamburger/fag etc. in the other hand for a moment!
Seriously, everyone should be aware that they should only be touching their satnav when it is safe to do so, so well said!
But I'm sure you can come up with some way of remembering the details and logging/reporting them later . |
Posted: Fri Apr 11, 2008 8:54 am Post subject: |
post-it notes |
john877 Lifetime Member
Posted: Wed Apr 16, 2008 9:14 pm Post subject: |
Could somebody explain to me how to work out the heading for the completion of the details in reporting a camera .
I know I may be a bit technically challenged but I have done a search of the forum but can no explanation on how to work out the heading .
thanks |
tonys66 Lifetime Member
Posted: Wed Apr 16, 2008 9:29 pm Post subject: |
Where you put all the info theres a circle with a load of numbers on it use that ie if you zoom in on the map and then look at the circle it will give you a idear of the heading . |
Posted: Wed Apr 16, 2008 9:46 pm Post subject: |
tonys66 wrote: | Where you put all the info theres a circle with a load of numbers on it use that ie if you zoom in on the map and then look at the circle it will give you a idear of the heading . |
Thanks I can see that now |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Wed Apr 16, 2008 11:40 pm Post subject: |
heading is the direction of travel in which you get caught - i.e. NOT the direction the camera faces!
MaFt |
Posted: Fri Apr 25, 2008 5:05 pm Post subject: |
1. Have you just tried downloading it again? I've had the occasional corrupted download of zipfiles before now.
2. Have you un-zipped the archive and extracted all the files before trying to delete the icons (sounds silly but I've done that before now) |
Posted: Sun Apr 27, 2008 2:37 pm Post subject: |
When you open the download select all the files within it then click the "Extract All" option, put the files into a folder on your desktop.
Now open the folder on the desktop and delete the bmp files that you no longer require before copying the remains to the device - Mike |
