Pocket GPS World :: View topic - Nüvi 760 audio output - Mono or stereo?
Feek
PostPosted: Sun Mar 16, 2008 6:55 pm    Post subject: Nüvi 760 audio output - Mono or stereo? Reply with quote
I've got a speaker nailed on my door pillar which I used to use with my Streetpilot 2610 and I want to use it with my new 760. The 2610 had the proprietary Garmin connector on so I'm recabling for the 760.
Is the audio output on the 3.5mm jack on the side of the 760 mono or stereo? I'm only going to a single speaker so will be forcing to mono if I have to but I want to make sure I get the right connector.
Thanks.
chris_ah1
PostPosted: Sun Mar 16, 2008 11:36 pm    Post subject: Reply with quote
it really doesn't matter. if you use a mono it will pick up one of the channels at least.
use stereo though since that's what it is.
Feek
PostPosted: Sun Mar 16, 2008 11:38 pm    Post subject: Reply with quote
It's more so I use the right connector, even if I use a stereo I'm going to be linking the two channels together but I'd rather slap a stereo plug up a stereo socket than use a mono one.
chris_ah1
PostPosted: Mon Mar 17, 2008 2:08 pm    Post subject: Reply with quote
well it's definitely stereo afaik.
Feek
PostPosted: Mon Mar 17, 2008 4:26 pm    Post subject: Reply with quote
It is, I've connected it all up but it really is very quiet from that socket, it's definitely a headphone socket rather than one for an external speaker. I'm going to have to fit a small amp between the unit and my speaker.
chris_ah1
PostPosted: Mon Mar 17, 2008 5:27 pm    Post subject: Reply with quote
perhaps there is a line-out mode in the software to boost it??? I'm sure you have volume up to full though for all sound modes (navi, music and system noises or whatever).
But yes, aux-out and even line-out at 3vrms needs some sort of amp to control the signal.
Most people will be putting it straight from the nuvi into the aux-in or cassette adapter of their radios so don't notice.
Feek
PostPosted: Mon Mar 17, 2008 5:43 pm    Post subject: Reply with quote
There's nothing obvious in the menus for that - I'm going to grab a Watson SP-180A from Ripoffs in Hockley which is a small amplified speaker - It's just a case of grafting the existing cable onto it and running some power up into it. That way I won't need to drive the output anywhere near as hard and will get a decent volume level. it's just about _usable_ as it is but I also want to load some audio books onto the GPS and it won't be any good for those.
chris_ah1
PostPosted: Tue Mar 18, 2008 1:12 am    Post subject: Reply with quote
yes, active speaker is the way to go - I wish i could remember the speaker, but there are some very small units that pack a hell of a wallop!
difficulty is powering it of course.
Not sure why you can't just use your on-board amp system?
Feek
PostPosted: Tue Mar 18, 2008 10:46 am    Post subject: Reply with quote
Because more often than not I have my iPod playing through the internal wireless in the car using an FM transmitter. I can't have the GPS interrupt that in any easy way and as the speaker I've got is a mere few inches from my ear it makes much more sense to use it.
chris_ah1
PostPosted: Tue Mar 18, 2008 1:27 pm    Post subject: Reply with quote
fair enough - most people would ditch the ipod now for the SD on board the garmin, but I sympathise with needing all my tunes being in one place as I'm the same Smile
Shame you didn't consider tomtom as that has ipod integration i think :p
Feek
PostPosted: Tue Mar 18, 2008 1:37 pm    Post subject: Reply with quote
Wouldn't touch TomTom, I've played with them and they just seem like a poor mans sat nav. I know that sounds offensive but it's not meant that way.
I've been using Garmin systems since the GPS II and this was the natural progression for me. Plus I only recently bought my iPod touch :D
22.094 (25 Sep 24)
