Pocket GPS World :: View topic - adding poi's to nuvi 310
gabbyevs
PostPosted: Thu Mar 13, 2008 10:35 pm    Post subject: adding poi's to nuvi 310 Reply with quote
just wondering when u add more does it override everything u had before or just add onto it?
also can u still only upload a certain amount
Steve208
PostPosted: Thu Mar 13, 2008 11:32 pm    Post subject: Reply with quote
Yep it over writes the POI you already have on the device. All Garmin sat navs have a max, some garmins have a max of 85 categories (i3) others have 257 as max, if you do a search you will find quite a few posts on this subject, look in "POI" section or "Garmin nuvi streetpilot other garmin" sections.
gabbyevs
PostPosted: Thu Mar 13, 2008 11:37 pm    Post subject: Reply with quote
ah right so i would have lost poi's i added last time
Steve208
PostPosted: Thu Mar 13, 2008 11:41 pm    Post subject: Reply with quote
Yep thats right all lost as it over rights the last lot, if you want to keep them in the future keep your POI's in a folder on your comp, then when you get some new ones, add them into the folder on your comp, then upload the whole folder, so reloading the ones already on the sat nav & the new ones you have added to the folder.
gabbyevs
PostPosted: Thu Mar 13, 2008 11:48 pm    Post subject: Reply with quote
ah right got it thanks very much:)
Steve208
PostPosted: Fri Mar 14, 2008 12:22 am    Post subject: Reply with quote
There is just one thing to watch if you go down this route, if you keep adding to the folder the number of POI will grow, if there is a max for your nuvi 310 you might well pass this & the first you will know is when your nuvi lockup when starting & its to late by then, so be careful with the number of POi you load.
PaulB2005
PostPosted: Fri Mar 14, 2008 9:13 am    Post subject: Reply with quote
The limit was 257 categories for the 310. However if you have firmware version 3.90 or later the limit has been removed.
gabbyevs
PostPosted: Mon Mar 17, 2008 5:36 pm    Post subject: Reply with quote
thanks paul not sure which version i got i have just updated though
is it the same for speed cameras will it just overwrite wotever is on there already
PaulB2005
PostPosted: Mon Mar 17, 2008 6:15 pm    Post subject: Reply with quote
The speed cameras are POIs too so when you add them you must add any other POIs (supermarkets, fuel etc) to the upload folder so POILoader uploads them all again each time.
gabbyevs
PostPosted: Mon Mar 17, 2008 6:17 pm    Post subject: Reply with quote
oh ok theyve all got to be in the same folder everytime then
PaulB2005
PostPosted: Mon Mar 17, 2008 6:19 pm    Post subject: Reply with quote
The same folder on your PC, yes. Keep all your POIs (including the Speed Cameras) in one folder on your PC. When you update any of those files reload the lot. POILoader asks you for a folder to upload. It'll upload any POIs you have in the folder you specify.
gabbyevs
PostPosted: Mon Mar 17, 2008 6:34 pm    Post subject: Reply with quote
right all updated and ive just checked im on firmware 4.0 so i should be ok
thanks for your help
PaulB2005
PostPosted: Mon Mar 17, 2008 6:48 pm    Post subject: Reply with quote
That's Ok.
Just for info, latest firmware for the 310 is 4.40 - Click Here
