strav100 Occasional Visitor
Posted: Sun Mar 16, 2008 1:25 pm Post subject: Lost computer voice Kate from Tomtom 720 |
She appears on my list on the tomtom unit but there is no sound after applying the latest update 5 days ago. The human voices work. Also there is no sound warning of speed cameras. I have enabled warnings using the speed cameras menu in the device - I have tried changing the sound alerts but when I try to change them there is no sound i.e clicking on 'Beep1' 'Beep2' 'Polite1' etc. there is no sound - I think the update has wiped the computer voice and all the sound alerts off the device ![Mad](modules/Forums/images/smiles/icon_mad.gif) |
Posted: Sun Mar 16, 2008 1:30 pm Post subject: |
Can you look at the the device using Windows Explorer, open the LoquendoTTS folder then EnglishGb this is where the TTS Kate voice is found (the folder is 43,9MB in size, for a working Kate voice), you can re-install the voice by inserting the CD that came with the device and use TomTom Home on the PC to put the voice back on the device - Mike |
dhn Frequent Visitor
Posted: Sun Mar 16, 2008 1:39 pm Post subject: |
mikealder wrote: | Can you look at the the device using Windows Explorer, open the LoquendoTTS folder then EnglishGb this is where the TTS Kate voice is found (the folder is 43,9MB in size, for a working Kate voice), you can re-install the voice by inserting the CD that came with the device and use TomTom Home on the PC to put the voice back on the device - Mike |
Some in North America are reporting a loss of Voice Recognition when they installed firmware 7.4x on their 720's this week. |
Andy_P Pocket GPS Moderator
Posted: Sun Mar 16, 2008 4:49 pm Post subject: |
No one's mentioned doing a reset yet.... ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Posted: Sun Mar 16, 2008 6:30 pm Post subject: |
I have 2 backups - 1) In a folder 'Original Tomtom backup' 2) In 'TomTom'
The first folders path is Original Tomtom backup/HOME/backup//GO/backup1/InternalMemory/LoquendoTTS/EnglishGb/Kate - This folder is 43.9 Mb
the English Gb folder has a Kate.vde file
There is also a separate InternalMemory/Voices folder with the following files Data04.chk and .vif / Data05 & 121 &162
The 'TomTom' folder has the same files
Do I just drag and drop these files into the Tomtom device like using it as a hard drive.
I cannot see the contents of my Tomtom at the moment until I get home as I don't have the dock with me
I can't find where the sounds are located on the back ups - a speed camera warning with no audible sound is useless!!! |
Posted: Sun Mar 16, 2008 7:21 pm Post subject: |
I would try Andy's suggestion first before messing around copying files, give a reset a try and report back if the unit is still being troublesome - Mike |
thebeast1234 Occasional Visitor
Posted: Tue Mar 18, 2008 10:53 am Post subject: |
I have a similar issue on my 710, I have just done the latest update v7.162, TomTom has rebooted and the first thing it says is the voice you selected is not available. I have tried a reset but to no avail, I have checked the LoquendoTTS folders on my backup and on the device and they are identical, what's also wierd is that in TomTom Home under voices it shows the Kate and Simon voices, but they are listed as being v6.7 is this relevant, they worked fine until I did the update? |
Allen_EP Occasional Visitor
Posted: Tue Mar 18, 2008 11:56 am Post subject: |
I could be wrong and I am sure some one will be along to correct me if I am. I thought TT disabled TTS in the 710 in one of their firmware updates/ |
Oldboy Pocket GPS Moderator
Posted: Tue Mar 18, 2008 2:06 pm Post subject: |
Allen_EP wrote: | I could be wrong and I am sure some one will be along to correct me if I am. I thought TT disabled TTS in the 710 in one of their firmware updates/ | Spot on.
Pre x20 Devices the TTS system was only licensed for the 910. _________________ Richard
agolder Occasional Visitor
Joined: Jan 08, 2008 Posts: 7 Location: West Yorkshire, UK
Posted: Tue Mar 18, 2008 7:40 pm Post subject: |
Also worth checking that sound isn't being routed to an external speaker or FM transmission.
Sounds obvious, but I had the same issue a while back and noticed by chance that the sound was being sent over FM transmission rather than the internal speaker - even though I hadn't selected this option. It's not happened since, so I reckon it was probably me accidentally selecting it sometime, but something I'll remember to check if I have the problem again...
edit... ignore me, just re-read your symptoms and don't think it's the same thing I'm talking about after all! oops! |
Quinny1 Lifetime Member
Joined: Mar 29, 2005 Posts: 202 Location: Ossett.West Yorkshire.UK.
Posted: Wed Mar 19, 2008 10:25 pm Post subject: |
Count yourself lucky that you've been able to silence a woman......
(Tin hat and bulletproof vest applied. ) |
nickn5 Occasional Visitor
Posted: Fri Mar 21, 2008 12:46 am Post subject: |
I found by chance that it is possible to Add new computer voices to the Go using Home, not on the 'Add new voices' icon under 'Add Maps, Voices etc.' but on the second page, where it says 'Add new computer voices'!
They're all about 45MB files though, but I have deleted Kate and have Simon installed instead, with Willem also installed ready for my Netherlands trip... _________________ TomTom Go720 (no T, thanks)
PGPSW Speedcams UK and EUR |
