Pocket GPS World :: View topic - tom tom one version2 help needed
hardtail
PostPosted: Sat Mar 15, 2008 12:06 pm    Post subject: tom tom one version2 help needed Reply with quote
hi guys ive just updated my tom tom one to version 7.162 and ive lost all my camera warning sounds i.e warning gatso 30 etc does any one no where i can get the new data.chk file to replace it with im desperate here Sad Sad Sad
PostPosted: Sat Mar 15, 2008 12:10 pm    Post subject: Reply with quote
You won't find a modified data.chk file as that method is not supported, instead have a read through THIS Page which details how to get spoken alerts using the new method and houses the various voice pack downloads - Mike
hardtail
PostPosted: Sat Mar 15, 2008 12:27 pm    Post subject: Reply with quote
Hi m8 ive done that copyed the ogg files into the map folder where my poi are but after i set the distance to the camera it then goes to the sounds and they are just the bell ,cookoo sounds no spoken sounds
PostPosted: Sat Mar 15, 2008 12:35 pm    Post subject: Reply with quote
Can you check which speed camera database you have got installed, is it single file, consolidated by type or speed zoned, also make sure the spoken alert voice pack you have downloaded matches the camera database type. The file names have to be the same for this to work, for each POI category there will be three files within the map folder:
pocketgps_uk_gatso_30.ov2 (the database containing locations)
pocketgps_uk_gatso_30.ogg (the spoken alert)
You haven't re-named any of the POI files or voice files per chance have you? - Mike
hardtail
PostPosted: Sat Mar 15, 2008 12:44 pm    Post subject: Reply with quote
hi m8 ive got the consolidated camera files and no i havent renamed any files which do i need to do
PostPosted: Sat Mar 15, 2008 12:49 pm    Post subject: Reply with quote
So long as you have the consolidated speed camera database files and the consolidated voice pack it will work, you don't need to re-name any files at all, the only reason I asked is because some people have re-named files in the past and had the same problem.
Can you open the map folder using Windows Explorer and double check that for each .ov2 file there is a coresponding .bmp AND .ogg - Mike
hardtail
PostPosted: Sat Mar 15, 2008 12:57 pm    Post subject: Reply with quote
is the consolidated cameras the ones where it say gatso 30 ,gatso 40 etc
hardtail
PostPosted: Sat Mar 15, 2008 1:03 pm    Post subject: Reply with quote
think im getting there its now working with the spoken warnings but where the mobiles are it saying warning gatso ahead
hardtail
PostPosted: Sat Mar 15, 2008 2:03 pm    Post subject: Reply with quote
all sorted now mate got there in the end Laughing Out Loud one more thing is there any way to update my maps from apart from paying tom tom again
PostPosted: Sat Mar 15, 2008 3:12 pm    Post subject: Reply with quote
'Fraid not.
If you bought a paper map you wouldn't be able to go back to the shop after a couple of years and swap it for a new one. That's how companies make their money.
If you've got a map later than v675.1409 you can use MapShare from TomTom to make and receive MINOR changes, but no new roads or anything.
