Pocket GPS World :: View topic - Removing unwanted stuff from a Nuvi 760
Feek
PostPosted: Tue Mar 04, 2008 8:45 pm    Post subject: Removing unwanted stuff from a Nuvi 760 Reply with quote
There are some things on my Nuvi 760 which I'm not interested in - The Garmin supplied camera database, all the foreign language voices etc etc.
Assuming I make backups, is it OK to simply delete things like the unwanted CyclopsSample files in the \garmin\poi directory and the unwanted voices from the \garmin\voice directory etc etc?
skes
PostPosted: Fri Mar 07, 2008 3:08 pm    Post subject: Reply with quote
I did and it still works.
PaulB2005
PostPosted: Fri Mar 07, 2008 4:57 pm    Post subject: Reply with quote
How much space did you gain?
skes
PostPosted: Mon Mar 10, 2008 3:20 pm    Post subject: Reply with quote
Roughly about 300mb
chris_ah1
PostPosted: Mon Mar 10, 2008 6:05 pm    Post subject: Reply with quote
does the unit run faster without the bloat?
300MB on a 2GB device is not bad.
skes
PostPosted: Mon Mar 10, 2008 10:24 pm    Post subject: Reply with quote
Haven't noticed any difference.
Should imagine it wont make any difference because it's mostly stuff thats not loaded into memory unless needed.
Feek
PostPosted: Tue Mar 11, 2008 10:05 pm    Post subject: Reply with quote
I've done it, didn't speed anything up but just freed up some space. All still works as expected.
kshotton45
PostPosted: Sat Mar 15, 2008 9:40 am    Post subject: Reply with quote
There's also some Audible files, some Help files in other languages and in the Text file there's loads of different languages. Does anyone know if it's O.K to delete these ?
Thanks Keith.
Feek
PostPosted: Sat Mar 15, 2008 10:38 am    Post subject: Reply with quote
Yes you can, I've deleted all the Audible stuff and the only thing left in my help directory is British_English and all is working well.
spacerunner
PostPosted: Tue Mar 25, 2008 6:51 pm    Post subject: Reply with quote
Do you have to delete the Garmin speed camera data base to be able to use the PGPSW camera files. If not, how does the unit distinguish between the two sets of data. If both sets are present will it cause problems?
PaulB2005
PostPosted: Tue Mar 25, 2008 6:55 pm    Post subject: Reply with quote
You don't have to. You can just switch them off in the Tools, Settings, Proximity Points, Change... screen by unticking Garmin Safety Cameras.
Best you do switch them off otherwise you'll get duplicate and out of date alerts....
spacerunner
PostPosted: Tue Mar 25, 2008 7:15 pm    Post subject: Reply with quote
Thanks...never thought of that! Confused
23.054 (28 May 25)
