Pocket GPS World :: View topic - tomtom go720
tomtom go720
theberties
PostPosted: Thu Mar 13, 2008 2:58 pm    Post subject: tomtom go720 Reply with quote
for some reason when travelling from A46 Coventry area going towards M5 directions send me down M40 south to the next junction, round the roundabout and then back onto M40 instead of going onto M40 north, is it likely to be a mapping error or is there something in the settings i should change
bertie
PostPosted: Thu Mar 13, 2008 3:06 pm    Post subject: Reply with quote
For any question like this, the first thing you really need to tell us is the MAP version and the SOFTWARE version you're using. Then we can say whether it is a software glitch or a mapping error and whether it has been corrected in later versions already (or only appeared in later versions!!)
It's probably an error in the speed assigned to a single section of road.
You can check that by using the MapShare reporting facility if you have it. Unfortunately, there's nothing you can do (yet) to correct it yourself.
Navcore 8 will have the facility to change speed limits for road segments, but I'm not sure if that will also change the speed it uses for calculating times.
CrispyUK
Sounds like someone has blocked the 'logical' sliproad route using MapShare?
Johnny_D
PostPosted: Thu Mar 13, 2008 3:10 pm    Post subject: Reply with quote
My thoughts exactly.
Has the opening poster downloaded the mapshare updates? If so what level of 'security' did you do?
JD
TTG 300 Died the death of a cracked screen
Navman F20 USB Fell off
TTG 520 Third time lucky?
Bloody Superb PGPSW Camera Database.
Not much else!
Oldboy
PostPosted: Thu Mar 13, 2008 3:16 pm    Post subject: Reply with quote
I think it's the same problem that was discussed from This Post.
TT Via 135 App 12.075: Europe Map v1135
PostPosted: Thu Mar 13, 2008 3:24 pm    Post subject: Reply with quote
For info, if you mean the area around N 52.25802 W 1.60037, it's still doing it on my Go720 with v7.221 software and v715 maps (on "fastest" route)
AND it doesn't matter if I'm using MapShare corrections or not... so it's not that.
Edit: well remembered Richard... Smile
Johnny_D
PostPosted: Thu Mar 13, 2008 3:29 pm    Post subject: Reply with quote
That's a .
Must be a mapping error.
JD
Not much else!
PostPosted: Thu Mar 13, 2008 3:49 pm    Post subject: Reply with quote
In which case, maybe you CAN correct it with mapshare yourself (if it is a blocked section of roundabout, rather than an incorrect speed.
Go read that other post carefully, (as I'm about to do!)
uffe73
PostPosted: Thu Mar 13, 2008 5:47 pm    Post subject: Reply with quote
Ah the old classic Longbridge Roundabout is back in the forum. Very Happy Try select the shortest route and you will be directed the correct way. The problem comes from incorrect map data for the roundabout which was discussed in the previous thread.
theberties
PostPosted: Thu Mar 13, 2008 6:09 pm    Post subject: Reply with quote
thanks for replys. i have downloaded map share but hasn't made any difference. not a problem to me as i knew where i was going but i wondered why daughter in law got lost.
bertie
22.094 (25 Sep 24)
