Pocket GPS World :: View topic - .itn files
.itn files
markfraser
PostPosted: Thu May 06, 2004 3:51 pm    Post subject: .itn files Reply with quote
Is Navigator the only app that can make the .itn files is uses for itinerary mode? It would be nice to export from something like Autoroute. If TomTom made a similar PC app which could export to .itn, I'd buy it!
PostPosted: Thu May 06, 2004 5:12 pm    Post subject: Reply with quote
Hey, Oldie, where are you? Maybe something you want to look into?
Oldie
PostPosted: Thu May 06, 2004 6:36 pm    Post subject: Reply with quote
Funny you should say that. I have done it Thumbs Up
As soon as I got my TTN3 upgrade I created a .itn file and I have now added it to version 3.01 of my POIConverter program. The new version of POIConverter will be released soon. It will import a route from AutoRoute, MapSource and Memory-Map Navigator and write it in .itn format. However, because of slight differences in the mapping it is advisable to examine the placement of the imported Drive-by points in TTN3. The Itinerary creation/editing features provided by TomTom are very good and it is easy to select Drive-by points, look at them on the map and adjust them as required.
Wizzo
PostPosted: Thu May 06, 2004 6:52 pm    Post subject: Reply with quote
Think Oldie said in another thread he was going to have a look to see if it could be done.
I've had a go but can't get the files to convert correctly Sad
So Oldie it look like it's up to you to save the day Laughing
Wizzo
PostPosted: Thu May 06, 2004 6:57 pm    Post subject: Reply with quote
Boy, Oldie that was quick you saved the day before I posted !! :P
Oldie
PostPosted: Thu May 06, 2004 8:11 pm    Post subject: Reply with quote
and now here is your chance to try it :D
I have just posted POIConverter v3.01 on my website http://rjdavies.users.btopenworld.com in the Programs | POIConverter area. It will read and write TTN3 Itinerary files but check that the transferred Drive-by points etc are where you want them to be. I have used it to set a preferred route, but I needed to tweak some of the points in TTN3. For example, if the transferred point is on the wrong side of a dual carriageway then the TTN router will find some way of passing through it.
The new version also supports Excel files, but at the moment there is a problem associated with multiple Excel file reads/writes. I am waiting for a bugfix to the library that I use.
Wizzo
PostPosted: Thu May 06, 2004 9:56 pm    Post subject: Reply with quote
Oldie,
I'm having a problem opening the axe file your POI format conversion program. I keep getting a error message Crying or Very sad
The st2gpx utility failed to produce the file -
C:\Documents and Settings......etc
Any ideas what I doing wrong ?
using xp and autoroute 2004
Oldie
PostPosted: Thu May 06, 2004 10:16 pm    Post subject: Reply with quote
Wizzo,
Sorry to hear that you are having a problem. I have come across this before and was unable to resolve it because when the .axe file was sent to me I was able to read it without any trouble.
Create a file named debug.yes in the same folder as POIConverter.exe then rerun the program. This should produce a file debug.txt in the program folder which might help me track down what is wrong. I could also try your .axe file if you emailed it to me.
I would like to find out why POIConverter fails on some systems.
Oldie
PostPosted: Thu May 06, 2004 10:22 pm    Post subject: Reply with quote
Wizzo,
Was the map file still open in AutoRoute when you ran POIConverter? With AutoRoute 2001 on my XP system it would work either way, but perhaps it is different with AR 2004.
Oldie
PostPosted: Thu May 06, 2004 10:59 pm    Post subject: Reply with quote
Wizzo,
I think that I have tracked down the problem. It appears to be associated with spaces in the path to the program name ST2GPX. Please try this
Copy the POIConverter folder (and subfolder) from c:\program files\richard davies\ to c:\ and run POIConverter from there. Please let me know if this works.
Sorry that it didn't work first time. I will remove the link to the program from my website until I have solved the problem.
Oldie
PostPosted: Fri May 07, 2004 1:34 pm    Post subject: Reply with quote
Wizzo,
I have just posted POIConverter version 3.02 in the Programs | POIConverter area on my website http://rjdavies.users.btopenworld.com
The new version will install into the C:\Richard_Davies\POIConverter folder. The spaces in the original path name caused ST2GPX to fail, although I can't really understand why. I will pass on my findings to the author of ST2GPX to see if he can help.
Wizzo
PostPosted: Fri May 07, 2004 6:43 pm    Post subject: Reply with quote
Oldie,
Sorry you have had such a one sided conversation so far I've been at work and accessing the site is too slow via my mobile and PPC with the sites having server speed problems.
Anyway it looks like you have done a lot without me.
Before I load ver 3.02 would you like me too make and send you the error file ? I'm also happy to send you my axe if it helps your understanding and yes I'm using autoroute 2004 and no the file was not open in autoroute.
Thanks very much for all the time and trouble you have gone to in provided us all with a great program. Thumbs Up
Oldie
PostPosted: Fri May 07, 2004 6:59 pm    Post subject: Reply with quote
Wizzo,
Thank you for offering to send the files but there is no need now as I think that I have got to the bottom of the problem. I have just heard from a user in Slovenia who first flagged up the problem with version 2 and 3.02 works for him now :D
Version 3.02 uses a different default directory which gets round the problem. I have contacted the author of ST2GPX and he is working on an improved version which should get rid of the bug.
Please let me know if you have any problems.
Wizzo
PostPosted: Fri May 07, 2004 7:16 pm    Post subject: Reply with quote
Oldie,
Just to confirm ver 3.02 works as advertised. :D
well done. Thumbs Up
22.062 (12 Jun 24)
