Pocket GPS World :: View topic - Help with removing files from Sd card please.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
madalex
PostPosted: Thu May 06, 2004 4:01 pm    Post subject: Help with removing files from Sd card please. Reply with quote
Complete novice to Pocket PCs. Please help.
Does anyone know how to remove files from an SD card? 8O Confused
clivers
PostPosted: Thu May 06, 2004 4:12 pm    Post subject: Reply with quote
you should be able to browse and delete them with it connected to your desktop pc.
just select the mobile device in windows explorer
madalex
PostPosted: Thu May 06, 2004 4:26 pm    Post subject: SD card Reply with quote
Cheers clivers...all gone :D
DavidW
PostPosted: Fri May 07, 2004 1:27 pm    Post subject: Reply with quote
Just to amplify the correct advice already given, when you first open Mobile Device, you get the contents of the My Documents folder. If you want to see other folders on the Pocket PC, such as storage cards, you need to open My Pocket PC inside Mobile Device.
Other options include using a SD card reader - these devices are highly recommended, not least as manipulating SD cards via ActiveSync is very slow unless you're fortunate enough to have a network (most likely wireless LAN) connection to use ActiveSync across.
clansfolk
PostPosted: Sat May 29, 2004 2:49 pm    Post subject: Reply with quote
Hold on stylus on file till menu appears and then choose "Delete", for MP3s and other such file works for me when away from a PC for programs unistall.
Pete
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
