Pocket GPS World :: View topic - Unit on to be charged?
Razer
PostPosted: Thu May 06, 2004 8:42 am    Post subject: Unit on to be charged? Reply with quote
Does the fortuna have to be turned on to be charged? I recieved mine yesterday and after fiddling with the battery contacts to get a proper connection i put it on charge.
If i left it in the off posistion then the battery light stayed red (it says in the manual amber for charging) If i turn the unit on then the light changed to amber, and then eventually green when it was charged
Anyone?
Privateer
PostPosted: Thu May 06, 2004 12:27 pm    Post subject: Reply with quote
Hi Razor,
Are you talking about the Fortuna Clip-On?
If so, then you should be able to charge it when it’s either switched on or switched off. I charge my Clip-On when it’s switched off. Charging time should be less than 3 hours. Thumbs Up
Robert.
Garmin Camper 770 LMT-D
Razer
PostPosted: Thu May 06, 2004 12:41 pm    Post subject: Reply with quote
Sorry, yes, i was referring to the clip-on.
I only ask because when the unit is 'off' the red light comes on, which the manual says is low charge. The only way to get the orange light was to turn the unit to the 'on' position
Does yours do the same as this?
Privateer
PostPosted: Thu May 06, 2004 12:52 pm    Post subject: Reply with quote
Hi Razor,
Sorry, I should have confirmed! Embarassed
Yes my Fortuna Clip-On behaves the same as yours does.
Charging when switched on: Amber light
Charging when switched off: Red light
When fully charged: Green light
Robert.
Razer
PostPosted: Thu May 06, 2004 2:02 pm    Post subject: Reply with quote
Thanks for that
22.054 (22 May 24)
