Pocket GPS World :: View topic - Start Up and Shut Down Images
Goto page Previous  1, 2
Cinkel
PostPosted: Wed Mar 05, 2008 7:01 pm    Post subject: Reply with quote
yes Andy, have original on a back up. tried resetting and starting from beginning. everything works great. except, when i try and add new start up and shut down images, the new start up image comes on for both start up and shut down. it's crazy.
PostPosted: Wed Mar 05, 2008 7:08 pm    Post subject: Reply with quote
So it HAS to be your image format.
What happens if you take the original image that DOES work, import it into whatever "paint" program you've been using and just alter it slightly (draw a red squiggle over it or something) then re-save it (somewhere else! so you don't overwrite the original) and put that on the Go.
renzhe
PostPosted: Mon Mar 31, 2008 4:50 am    Post subject: Reply with quote
LISTEN TO ANDY_p2002 !!!
THIS WORKS TRUST ME, I WAS LOOKING FOR AN AWNSER AND THIS WORKED
ILL REPEAT THE STEPS!!
Go to Change Pref. -Page 1- Safety Pref. VERY LAST BOX CHECK IT!! DONE!!!
Reset GPS
Andy_P2002 wrote:
European models are the same, dhn...
All widescreen TomToms have the "w" at the end of the splashscreen names.
And the shutdown screen in v7 software is called "antitheft.bmp" or "antitheftw.bmp" (not "suspend" anymore).
Finally, to show the shutdown screen, you need to set the option "warn not to leave the device in the car", which is the last option on the first page of "Safety Preferences".
Page 2 of 2
22.064 (26 Jun 24)
