craigc38 Occasional Visitor
Posted: Sat Mar 01, 2008 12:46 pm Post subject: TOMTOM ONE 1st edition (UK)-help much needed with root files |
I contacted tomtom yesturday after i reported my screen would freeze on welcome screen, he emailed me instructions to update root files. I needed to delete all root files on tomtom but leave the folders then tomtom home would update and install updated root files.
This did not work and im now totally stuck, is it possible to find these files elsewhere? So i can just paste them on my SD card?
I have tried absolutley everything |
GerryC Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/web.jpg)
Posted: Sat Mar 01, 2008 3:41 pm Post subject: |
Any instructions I've seen regarding deleting files from the root folder start with making a backup.
Full instructions were pasted here.
If you used Home to backup, the files should be under C:\Documents and Settings\(username)\My Documents\TomTom\HOME\Backups\GO if you haven't changed it from defaults. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sat Mar 01, 2008 4:47 pm Post subject: Re: TOMTOM ONE 1st edition (UK)-help much needed with root f |
craigc38 wrote: | This did not work and im now totally stuck, | Can you tell us what happened when you connected to HOME?
It would give us some idea of where the problem might be. _________________ Richard
Posted: Sat Mar 01, 2008 6:35 pm Post subject: |
when i connected to home it would then search for updates then come back with a message "must not be empty".
How would the backup help if the files are no good anyway?
Rgds |
Posted: Sat Mar 01, 2008 6:47 pm Post subject: |
can i get the older tt home from somewhere? that migt help cos i also get the xulrunner.exe problem |
Posted: Sat Mar 01, 2008 7:15 pm Post subject: |
Have a look Here.
There is also an older version for the ONE if you want to try it.
craigc38 wrote: | when i connected to home it would then search for updates then come back with a message "must not be empty". | You haven't remove everything from the SD Card, have you? _________________ Richard
Posted: Sat Mar 01, 2008 7:24 pm Post subject: |
I just removed the loose files not the folders (or the contents).
Just really annoying me now,
Cheers |
Posted: Sat Mar 01, 2008 7:30 pm Post subject: |
If you download the V6.560 for the ONE, on the page I linked to, you can copy the Files to the Device using Explorer. There is a Read Me in the Zip File.
HOME should then offer to update this to the latest version for you. _________________ Richard
Posted: Sun Mar 02, 2008 5:29 pm Post subject: |
still no joy
Do i need a file called "current map data"?
Its really winding me up... should I just leave it with tomtom customer service to help? |
Posted: Sun Mar 02, 2008 9:01 pm Post subject: |
craigc38 wrote: | still no joy ![Question](modules/Forums/images/smiles/icon_question.gif) | What have you done, and what happens now? _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Sun Mar 02, 2008 9:11 pm Post subject: |
Rather than just saying "still no joy", it will really help if you say what exactly you did and what exactly went wrong. Speeds the diagnosis up when we can't see what you're doing!
If I read it correctly, Oldboy is asking you to download a set of system files from his website and to paste those onto your TomTom using windows Explorer.
The version for the One (v6.560) doesn't have the file you mention. Just do as he suggests (and as the text file says) and report back. |
Posted: Sun Mar 02, 2008 9:46 pm Post subject: |
i done as suggested but ttone still didnt get past the welcome screen, even on the home updates i just got the application update and camera updates.... still freezing on welcome screen.
I thought "current map data" was one of the rquired files to enable the tomtom to work, i may well be wrong though
Thanks in advance |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sun Mar 02, 2008 9:49 pm Post subject: |
With the replacement file set on the device, if it isn't booting up fully have you tried pressing and holding the reset button for thirty seconds, then switch back on see what it does? - Mike |
Posted: Sun Mar 02, 2008 9:53 pm Post subject: |
Can you paste a list of what files you now have on your device? (be nice to have folder names too, but no need to list contents of folders.
A handy utility called "DriveZ" can produce listings, to save you having to type it all out yourself. Just make sure it is set to show the file extensions. |
Posted: Mon Mar 03, 2008 10:48 am Post subject: |
Ok,
Got it turning on now, just no map found error.
Im affraid of using tomtom home cos thats when it goes pear shaped for me, where can I can my basic Great Britain map from?
Rgds |
