DraySoft Lifetime Member
Joined: Dec 04, 2005 Posts: 30 Location: Rugeley, Staffs
Posted: Mon Feb 25, 2008 10:43 pm Post subject: |
Hi All,
Have all these "TMC's working fine" still got the well known '1Min delay' problem or is it just mine - not much use when you don't know the exact delay
My first TMC had to be returned as the lead between the plug and the receiver went open circuit and my 720 could not detect it, replacement works fine.
I took Darren's advice and bought a Carcomm mount Part Number: CNM-160. I think the constant pluging and unpluging every time I got out of my van may have damaged the lead, now I just remove the 720 from it's mount.
Draysoft. |
Posted: Tue Feb 26, 2008 8:21 am Post subject: |
The delay timing errors are down to the version 7 software, we are still awaiting an update to fix this problem - Mike |
portman Frequent Visitor
Posted: Tue Feb 26, 2008 11:19 pm Post subject: |
Has anyone tried the new one around Europe, do you get a license for Germany etc? Or are you limited to the country of first use? _________________ Samsung Mega
Tomtom 500
kattt Occasional Visitor
Posted: Thu Feb 28, 2008 10:24 pm Post subject: |
If anyone's curious about what's in the latest version (V400.013), I couldn't resist taking apart the plastic bit.
Note that VCC is +3.3V, and it won't just click back together - you have to use tape or glue. Ignore the bright red/green bits - my scanner is crap.
Posted: Thu Feb 28, 2008 10:45 pm Post subject: |
kattt wrote: | Ignore the bright red/green bits - my scanner is crap. | So is the soldering when you look at that - although you didn't do that part - Mike |
gardenshed Frequent Visitor
Posted: Fri Feb 29, 2008 9:04 pm Post subject: |
nice of them to put all the values of the components on the pcb for us to make a replacement or repair  |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Fri Feb 29, 2008 10:59 pm Post subject: |
The soldering on that one is a lot better than the one I have just wired up to my car aerial.
Andy |
