yebaws Occasional Visitor
Posted: Sat Dec 01, 2007 11:44 pm Post subject: |
mikealder wrote: | Yes that syntax will work and allow you to knock off the tips, if you want any help with the menu text or configuration let us know as we can post up a suggested text to load to the device.
The One Third Edition can even display and use text documents with the correct command line in the menu should you need this - Mike |
Followed your instructions to the letter - new file named TomTom.mnu placed in a new folder called SdkRegistry in the root directory. Text in file as per the text in your review plus the extra line at the bottom. Then shut down and re-started, but no change to the menus.
Any ideas?
Thanks,
Justin |
Posted: Sun Dec 02, 2007 6:36 am Post subject: |
The text I use is as follows (it is a mess but work as far as a menu is concerned but it does work):
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Main menu 1 of 3|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_MAINTAIN_POI|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Main menu 2 of 3|
MENUITEM|TASK_MENU_PLAN_ATOB|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_DELETE_ROUTE|
MENUITEM|TASK_MENU_TRAFFIC|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Main menu 3 of 3|
MENUITEM|TASK_DOC_BROWSER|
MENUITEM|TASK_SWITCH_TIPS|
MENUITEM|TASK_PAGE1|
Make sure your SdkRegistry folder is correctly named and the file TomTom.mnu must only have a single file extension (the .mnu part).
Try a copy/ paste wih the above text into your menu file use it to replace whatever you have in there currently, and see if that works, if not let me know and I will send you the file that I know works - Mike |
Posted: Sun Dec 02, 2007 11:28 am Post subject: |
Thanks! Worked this time using this text! |
Andy_P Pocket GPS Moderator
Posted: Sun Dec 02, 2007 8:34 pm Post subject: |
yebaws wrote: | mikealder wrote: | But what device is it? - there is loads on confusion with respect to numbers and versions etc. Look at the box and does it say "One Third Edition" if you don't have the box to hand does the device have an SD card slot on the base plate or not? - Mike |
Deffinately tomtom one version 3 (W europe). Only had it a couple of weeks and the box is sitting here...
No sd card, internal 1gb memory |
Sorry to bang on about this, but for future reference, a "V3" is NOT the same as a "3rd Edition"
It gets complicated, but basically a "v3" is one of the two versions of the "New Edition" (which isn't the new one any more so TT renamed it the "2nd Edition"!)
What does your box say? From your description you have a 3rd Ed. |
Posted: Sun Dec 02, 2007 10:29 pm Post subject: |
Andy_P2002 wrote: | yebaws wrote: | mikealder wrote: | But what device is it? - there is loads on confusion with respect to numbers and versions etc. Look at the box and does it say "One Third Edition" if you don't have the box to hand does the device have an SD card slot on the base plate or not? - Mike |
Says 3rd edition on the bottom of the machine. On the box it says 3rd edition and 3rd version (although I think the latter is a 3rd edition in another language...) |
Kar98 Lifetime Member
Joined: Nov 25, 2004 Posts: 344 Location: DFW, Texas, USA
Posted: Mon Dec 03, 2007 6:20 pm Post subject: |
Hehehe, I didn't even /get/ a box with mine. This one came in a transparent plastic package. On the other hand, the US version has "1" GB storage (978.1 MB, not 1,024MB), instead of 512 MB. |
Posted: Mon Dec 03, 2007 6:23 pm Post subject: |
In the UK there are two versions: a "regional one with UK mapping and 512MB memory, and a "europe" version with 1GB memory. |
Posted: Mon Dec 03, 2007 8:38 pm Post subject: |
Andy_P2002 wrote: | In the UK there are two versions: a "regional one with UK mapping and 512MB memory, and a "europe" version with 1GB memory. |
Mine is the W Europe 1BG version. Have just used it in Spain and found it a bit deficient when it came to small roads - compared to Navigon Navigator. I suppose something's got to go to get the whole of W Europe on 1GB. Wondered if anyone knew whether the UK mapping on the W Europe version is the same as the UK only version or if that has been reduced down too? |
Posted: Tue Dec 04, 2007 1:29 am Post subject: |
You're the third person to ask that in the last couple of days!
To all intents and purposes they are the same. |
AkGriso Occasional Visitor
Posted: Mon Feb 25, 2008 10:44 pm Post subject: |
Mike A.....Thanks for your tip on custom Menu re: itinerary planning on the TT 3 edition. Now It is on the Menu....I pushed the correct button............So I've something to do while sitting in the garage waiting for spring.
CENAT (College Educated Novice Apprentice Trainee)
jim |
jmed99 Occasional Visitor
Posted: Sat Jan 31, 2009 3:26 pm Post subject: |
I have a tomtom ONE 130s and was wondering if there's anyway to disable the tips? They are soooo annoying!
Thanks! |
Posted: Sat Jan 31, 2009 3:30 pm Post subject: |
Welcome to the forum, assuming your device works in the same way as all the others:
Change Preferences/ show tips press it so it puts a red cross through the icon, if you cannot see the show tips/ hide tips icon then you will need to go to Change Preferences/ Show ALL menu options now you should be able to see the show tips/ hide tips - Mike |
Posted: Sat Jan 31, 2009 4:05 pm Post subject: |
mikealder wrote: | Welcome to the forum, assuming your device works in the same way as all the others:
Thanks Mike, but I don't have a Show All under change preferences. |
Posted: Sat Jan 31, 2009 10:07 pm Post subject: |
Any ideas?
Thanks! |
Posted: Sun Feb 01, 2009 12:03 am Post subject: |
Have you tried the custom menu on the device as outlined near the top of page two of this thread? - Mike |
