a10user Occasional Visitor
Posted: Wed Feb 20, 2008 8:18 pm Post subject: |
FrequentFlyer wrote: | News to me.... I didn't receive the above. |
Nether did I |
LostMike Frequent Visitor
Joined: Jan 17, 2008 Posts: 369 Location: Monmouthshire
Posted: Sun Apr 20, 2008 3:25 pm Post subject: |
I believe that the battery pack is supposed to recharge via the USB cable. I have also noticed that my rechargeables appear to recharge when the A10 is connected via the USB cable.
So.... what happens if you have disposables in when it when connected via the USB. Normally you are warned not to try recharging them!
It would be a shame to inadvertently blow the device up. _________________ LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525 |
robertharvey Occasional Visitor
Posted: Mon Apr 21, 2008 9:56 pm Post subject: |
LostMike wrote: | I believe that the battery pack is supposed to recharge via the USB cable. I have also noticed that my rechargeables appear to recharge when the A10 is connected via the USB cable. |
I just tried this and it works with my NiMh batteries. Can anyone shed any light on what this circutry is doing (Voltage, Constant Current?) and whether it is safe to leave NiMh batterries on charge overnight. A lovely feature if it works. USB car adaptor and your sorted!
Hold that, charge only lasted a few minutes, Must have been a rest effect. :-( |
super_claret Occasional Visitor
Posted: Sun Apr 27, 2008 11:02 am Post subject: |
Just purchased the LiPol rechargeable battery and charged it overnight for about 14 hours in total (unit left on but on advanced powersave, screen off after 15 secs) and the ligtning symbol is still showing. The instructions say that the when fully charged, the lightning symbol will disappear. Does the unit really need to be charged in excess of 14 hours? I know it says that by turning the unit off it will re-charge faster, but it also says that from totally flat to full charge should take no more than 9 hours.
Presumably, I can re-charge the unit using the cigarette lighter connection while driving and also by plugging it into my USB port on my computer at work?
Many thanks
Mark |
PloddinPedro Regular Visitor
Posted: Sun Apr 27, 2008 11:37 am Post subject: |
super_claret wrote: | Just purchased the LiPol rechargeable battery and charged it overnight for about 14 hours in total (unit left on but on advanced powersave, screen off after 15 secs) and the ligtning symbol is still showing. The instructions say that the when fully charged, the lightning symbol will disappear. Does the unit really need to be charged in excess of 14 hours? I know it says that by turning the unit off it will re-charge faster, but it also says that from totally flat to full charge should take no more than 9 hours. Presumably, I can re-charge the unit using the cigarette lighter connection while driving and also by plugging it into my USB port on my computer at work? | Best thing is to run it down and recharge overnight a couple of times. Leave it switched off completely when charging i.e. after plugging it in, when the lightning symbol appears, switch it off. Yes it will charge via the USB / PC and the car, although I don't know if the car takes longer. |
Posted: Wed Apr 30, 2008 10:08 pm Post subject: |
I've now tried running the battery down a couple of times and re-charging with SatMap off, but still the lightning symbol stays on, even after a total of 18 hours continuous charge!!
I've emailed SatMap about this but had no reply yet. |
Posted: Thu May 01, 2008 7:16 am Post subject: |
super_claret wrote: | I've emailed SatMap about this but had no reply yet. | I strongly recommend a 'phone call - they're generally very helpful when you make contact but they don't seem very good at responding to e-mails; probably because they're too busy fielding 'phone calls! Bear in mind that they don't actually have a dedicated "Support" team. |
Posted: Thu May 01, 2008 7:41 am Post subject: |
The only information on this topic I can find is in the user guide:
"Note:If a Lithium Polymer battery is being charged (see section 2.06b), the four -bar battery icon is replaced by a solid charging battery icon."
You do still get the lightning symbol and mine stays this way even with the charger plugged in for 24 Hours. I am not too sure there is any indication when the battery has reached 100% other than the actual battery meter, but this is difficult to read for anything other than a simple look see. I very much doubt you can tell the difference between an 85% or 100% charge state - Mike |
Posted: Thu May 01, 2008 7:54 am Post subject: |
super_claret wrote: | ... The instructions say that the when fully charged, the lightning symbol will disappear. | Having re-read your original post, I think Mike Alder is right - the lightning symbol DOESN'T disappear when full charge is reached. Mine certainly doesn't. If I leave it on charge overnight, it will display four blocks when unplugged; if I then immediately plug it in again, the lightning symbol returns. I suspect your unit is actually being fully charged - in essence, the instructions are wrong. |
IanHibbert Occasional Visitor
Posted: Mon May 05, 2008 8:32 pm Post subject: |
Just back from a long weekend in the far North of Scotland:
Good News: the unit performed flawlessly on the mountain and the re-chargeable LiPol was still showing 2 bars after 9 hours use (15 sec screen time out set etc.)
Bad News: when I returned to the hotel to re-charge the unit, it was completely 'dead', i.e. plugging in the usb power supply, pressing the on/off switch etc, did nothing - the unit was lifeless. However, as soon as I removed the battery connector from the battery pack and re-connected, it sprang into life, proudly still displaying 2 bars! I thought this 'freeze' fault had been cured with 1.16? Good job it didn't happen mid storm....
I know they're about to release 1.18 to address larger capacity SD cards and longer routes - is this issue not yet resolved?
Cheers, |
Grahammon Occasional Visitor
Posted: Mon May 19, 2008 10:15 pm Post subject: Dead Battery |
New Satmap arrived, Went outside got a lock, played with it by walking up the street. turned it off. Just looked at it today Dead battery. aargh!
Checked the posts in this section and realised that I should take the batteries out between use.
Not sure this is acceptable. My car Navigation Garmin nuvi hasn't been used for over month now and having just checked it to make sure it still works! It does and has full charge. So why not the Activ 10.
Not sure why you have to pay an extra £50 pounds to get a long lasting battery that can stand the current drain.
and yes I did turn it off
Graham |
scotch_whisky Occasional Visitor
Posted: Tue May 20, 2008 12:29 pm Post subject: Re: Dead Battery |
Grahammon wrote: | and yes I did turn it off
Graham |
Trouble is you can't turn it off completely. Mine has, and I assume they all have, a constant 34mA drain so the batteries are always being discharged even when you think it is switched off.
The only solution is to remove the batteries. As you say this is not really acceptable but is becomes a habit after a while.
I was going to buy the "Lithium Ion" pack but I find that NiHM cells have actually quite a long life PROVIDED they are removed when not in use.
I did seriously consider returning mine because of this problem but if you want a "proper" OS map on a rugged hand held unit there really is no other viable option.
I guess we are all paying the penalty of being early adopters. If I had known of this and other well documented problems before I had bought it I might have stuck with my Garmin. I didn't and despite the problems it works rather well. No doubt the SATMAP MKII will be a much better unit but if you always wait for the next model you would never buy anything. |
Posted: Tue May 20, 2008 6:37 pm Post subject: |
Not sure there is a need to buy the pack.
I use 2700 mAh rechargeables and have no problem. I charge them before each trip and keep a set of energizer lithiums in the pouch just in case but in 6 months I have never needed the lithiums. _________________ LostMike
Satsync 1.525 |
cosmiccowboy Occasional Visitor
Posted: Tue May 20, 2008 7:51 pm Post subject: |
Hi. I have bought myself a Satmap a month ago, and up to now it has behaved itself with non of the problems that I have read about on this forum. I do have a question about powering the device though. At the moment I am using 2500 mha rechargeables and would like to use the "Lithium Ion" pack and keep the rechargeables as spare. my question is can I buy a "Lithium Ion" pack from other sources or are we stuck with Satmap's own pack?
cosmic |
Posted: Tue May 20, 2008 8:12 pm Post subject: |
I am not aware of any other third party accessories for the active10 or anyone else offering the Li Pol cell, so if you want one of these it will have to be a purchase direct from SatMap - Mike |
