swlawson Occasional Visitor
Joined: 18/03/2003 11:08:03 Posts: 5 Location: Manchester, UK
Posted: Thu Apr 29, 2004 10:39 am Post subject: TomTom3 and GPSDriver V3.x won't coexist with other GPS Apps |
I've been happily using TomTom2 on an IPAQ4150 together with MemoryMap software and a TomTom BT GPS receiver.
When I first started I soon hit the problem with TomTom tieing up the GPS port, and used the trick of deinstalling the 'TomTom ~GPS' program. This seemed to do a partial deinstallation as the driver still appeared in the program list and worked, but it no longer tied up the GPS COM port and allowed other applications to access the GPS receiver when TomTom wasn't running.
I even upgraded to GPS 3.01 still using TomTom2 and the deinstall trick still worked.
However I've now upgraded to TomTom3 and the deinstall no longer seems to work. Initially I upgraded the GPS driver to 3.02 straight away, but on deinstalling it it really did deinstall. It no longer appeared in the program list and TomTom3 hung when started (but it did let MemoryMap access the receiver). I reinstalled GPS 3.02 and tried again but it still deinstalled fully. I then tried GPS 3.01, but this did the same thing. So it seems to be the combination of TomTom3 and the GPS driver that's causing the problem.
Anyone got any ideas ?
Thanks. |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Thu Apr 29, 2004 2:25 pm Post subject: |
Sure. Go back to TomTom GPS 2.07 and refrain from upgrading the GPS driver _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Apr 30, 2004 8:11 am Post subject: |
Thanks - downgraded to 2.07 and everything now works.
Seems a bit unnatural going back to what sounds like a very old version, but if it 'does the business' then that's the main thing.
Thanks again,
Simon. |
Posted: Fri Apr 30, 2004 5:11 pm Post subject: |
Welcome to the club "The head scratchers"
When we asked TomTom about why on earth they are doing this they eventually came out with a response that they want to avoid service calls from average users about other BlueTooth hardware interfering with TomTom.
Eventually this is coming down to a fundamental question - does an application vendor assume they own the Pocket PC, or are they accepting their role as a guest, alongside other guests, on the Pocket PC that is owned by the user.
It is similiar to the discussion about install locations. There is absolutely no reason to force installs into main memory, yet many programs like TomTom, Alk Copilot, or SpaceMachine Pocket Map are blatantly ignoring the user's wish to install them to storage card, and are installing to main memory anyway.
And I thought ignorance was something that only exists in Texas... ![Mr. Green](modules/Forums/images/smiles/icon_mrgreen.gif) _________________ Lutz
Taz Regular Visitor
Posted: Sun May 02, 2004 1:46 pm Post subject: |
Any chance of a step by step guide of removing 3.2 and installing 2.7 please? I have both files unzipped on my pc.
Thanks |
Posted: Sun May 02, 2004 2:57 pm Post subject: |
see my answer in the other post. The only thing that is really important is to make sure no programs are running while you try to deinstall them. Since this is difficult to tell unless you use a task manager, you should always do a soft reset in between steps. _________________ Lutz
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Sun May 02, 2004 5:06 pm Post subject: Re: TomTom3 and GPSDriver V3.x won't coexist with other GPS |
swlawson wrote: | I even upgraded to GPS 3.01 still using TomTom2 and the deinstall trick still worked.
However I've now upgraded to TomTom3 and the deinstall no longer seems to work. Initially I upgraded the GPS driver to 3.02 straight away, but on deinstalling it it really did deinstall. It no longer appeared in the program list and TomTom3 hung when started (but it did let MemoryMap access the receiver). I reinstalled GPS 3.02 and tried again but it still deinstalled fully. I then tried GPS 3.01, but this did the same thing. So it seems to be the combination of TomTom3 and the GPS driver that's causing the problem. |
I have still had no problems on two Pocket PC's running an upgraded TTN3 and I have just upgraded to TTN 3.02 on both PPC's and uninstalled the TomTom ~ GPS driver, soft reset and had both TomTom 3 and also other apps working quite happily side by side. |
