Pocket GPS World :: View topic - Roaming maps?
Roaming maps?
Sandy
PostPosted: Sat May 01, 2004 11:09 am    Post subject: Roaming maps? Reply with quote
Hi guys,
I have just bought a hp 2210 and ttnav3.
Is there a way of roaming around a map?
Tia
sand Smile
SteveUK
PostPosted: Sat May 01, 2004 11:41 am    Post subject: Reply with quote
Hi Sandy,
This is no problem - once TT Navigator is running, you have a downward arrow in the top left corner of the screen which is a pull-down menu. Tap the arrow and select the first menu option (Map).
This will take you to the map screen where you can zoom in and out using the slider on the right, and you can pan the map in any direction by tapping and holding the map at any point and dragging it up/down/left/right as required.
You can of course also use the search icon at the bottom to find a particular street/toen or point of interest.
Good luck with your new toy - I'm sure you won't be disappointed with it.
Steve
Sandy
PostPosted: Sat May 01, 2004 11:56 am    Post subject: Reply with quote
Thanks Steve,
Will give it a try! Smile
DavidW
PostPosted: Sat May 01, 2004 1:39 pm    Post subject: Reply with quote
In addition, pressing up and down on the cursor pad changes the zoom level (this works in both map mode / split view and Navigator mode - assuming you haven't changed the default buttons in Navigator mode - there again, in Navigator mode, I find the autozooming is fine).
In either map mode or split view, using the icon like two sliders at the bottom of the screen you can decrease or increase the amount of road detail and place name detail, also turn POI display on or off.
Sandy
PostPosted: Sun May 02, 2004 11:47 am    Post subject: Reply with quote
Thanks Davidw,
All the hints and tips are useful!
Sand
22.064 (26 Jun 24)
