Pocket GPS World :: View topic - Info Required re Hardware Problem
chrisroberts
PostPosted: Sat Feb 09, 2008 3:45 pm    Post subject: Info Required re Hardware Problem Reply with quote
Having just renewed my sub and downloaded latest Speed Cam POIs, I find I can not upload them because the USB socket on my i3 is damaged. I tried to resolder it but failed due to back-to-back circuit board construction.
Having examined the transflash card on a reader, my question is: Does the file "poi.gpi" contain the factory POIs, or the custom ones? If the latter, is there an alternative way of loading new POIs directly onto the card?
Regards
Chris
Garmin nüvi 760 with CN NZ v3 maps; CN Europe 2012.30 maps, and 4.90 Firmware
PostPosted: Sat Feb 09, 2008 4:36 pm    Post subject: Reply with quote
Put the card in a card reader connected to the PC then point POILoader at the memory card and it will install the POI files to the card, once the card is back in the i3 it will use the POI files on the card - Mike
chrisroberts
PostPosted: Sat Feb 09, 2008 6:22 pm    Post subject: Reply with quote
Very many thanks for that Mike. It worked a treat. It's easy when you know how!
Best Wishes
Chris
22.094 (25 Sep 24)
